Found an old vid. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-14-2008, 05:42 AM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
Found an old vid.
I think this was the reason why my stock turbo took a dump.....lol but it was fun doing it.
http://videos.streetfire.net/video/3...oost_19028.htm
Back when all I had was a TS chip, intake and exhuast
lildevil02 is offline
post #2 of 14 (permalink) Old 03-14-2008, 05:57 AM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
Re: Found an old vid.
lol i love the only comment..."buddy you need a better BOV" wtf
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #3 of 14 (permalink) Old 03-14-2008, 06:10 AM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
yea i just saw that.....stupid ricers
post #4 of 14 (permalink) Old 03-14-2008, 06:28 AM
IA5520 Member
missmanj's Avatar
what is that sound coming from the turbo when it shifts, mine use to do that but i never really understood why?
2000 F250 7.3L 165,000
DP Tuner F5 Switch (Stock, High Idle, 40t, 80e, 140 Extreme, Lope Idle, 120 Race)
Rancho Nine Position RS9000XL Shocks
203* Thermostat
DIY Intake Napa 6637 Filter
CCV Mod
4" Straight Pipe Exhaust
ATS Turbo Housing
Powerslot Rotors & Hawk Pads
ISSPRO Gauges
Turbo Saver
Max AC Assist
Stancor GPR
missmanj is offline
post #5 of 14 (permalink) Old 03-14-2008, 06:31 AM
Banned
Send a message via Yahoo to blk99
your pyro didnt work!
blk99 is offline
post #6 of 14 (permalink) Old 03-14-2008, 06:34 AM
Banned
that is surge....
it does that cause the motor is dropping RPM's from the tranny shift but the turbo is still pushing full boost....and when the motor doesnt take as much air as the turbo is putting out, it surges....and thats why it drops and them comes back...
blk99 is offline
post #7 of 14 (permalink) Old 03-14-2008, 11:27 AM
Haul_n_horses2's Avatar
Originally Posted by blk99 View Post
that is surge....
No, that is turbo stall. Surge is when it oscillates and gives you that psst.... pssst.... psst.... sound. There is a good video of it around here someplace. Stall is normal and not detrimental to the turbo. Surge can snap the shaft.
On edit: Here is a video in which you can hear and see both.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #8 of 14 (permalink) Old 03-14-2008, 11:42 AM
< pissed off pumkin.
skylinedan's Avatar
Woosh, thats a normal sound when they shift . I think you just don,t hear it as much if at all with a stock intake. The sound is the air backing up through the intake track, like HH said.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #9 of 14 (permalink) Old 03-14-2008, 09:59 PM
Thanks for the link, I have been trying to figure out what surge sounds like. I have not heard anything like what is in the video yet, niether the noise at the shift, or the pulsing after the third (I think third) shift in the video which I assume was the surge.
2001 Excursion Preditor tuner, 4" Magna Flow exhaust, AFE II Dry-S, Front spring pack,
add a leaf in the rear, Rear Helwig, and Rancho 9000X all around, HPX, Reg Ret, IAH delete, SP exhaust brake, JW VB, Gauges: Boost, EGT, and tranny temp. Cooling mist EGT/boost, RAS
Waiting to install:
ITP prepump and intank
sheboyganjohn is offline
post #10 of 14 (permalink) Old 03-14-2008, 11:23 PM
Banned
somebody buy kainers a new steering wheel that should be good for a few ponies
whiteduallyil is offline
