Hose ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-13-2008, 04:23 PM Thread Starter
< pissed off pumkin.
skylinedan's Avatar
Talking Hose ?
Hey, I,ve got my mounting brakets and filters. I,m leaning towards Summit twist lock hose and fitings, anyone out there use it and how good is it. Any leak problems that kind of stuff ?
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #2 of 14 (permalink) Old 03-13-2008, 04:41 PM
Deputydog's Avatar
Re: Hose ?
Dan
I used push lock fittings in my filter base from Parker and it worked great. No problems but make sure and lube the hose up a bit with oil, they are a bugger to get on all the way.
Deputydog is offline
post #3 of 14 (permalink) Old 03-13-2008, 04:48 PM Thread Starter
skylinedan's Avatar
Talking Re: Hose ?
Thanks, I got my shoping list made out just need to call them and order it. I,m getting 20 feet of hose for the whole project. I have a trans cooler I,m converting to a fuel cooler, reason for the extra hose. I have to find out where to get a Walbro pump now also, I think my stocker is a bit weak, 120,000 miles has that effect, .
Dan
post #4 of 14 (permalink) Old 03-13-2008, 08:18 PM
Send a message via AIM to JohnT
Re: Hose ?
I used parker hose push-lok, and their fittings, it works very well. Once they are on, they are not coming off. I had to shorten my fuel line, and I already had the push-lok fitting on, and I wanted to try to pull it off, and it did not even budge. I ended up cutting it off.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #5 of 14 (permalink) Old 03-13-2008, 08:51 PM
Re: Hose ?
Put the hose in HOT water, and it makes life easier.
TerminatorEngineering is offline
post #6 of 14 (permalink) Old 03-14-2008, 05:19 AM
Needs more hours per day
jtharvey's Avatar
Re: Hose ?
If their twist-lok is basically the same as push-lok hose (looks like it is), you should have no problems with it. My whole fuel suppy system is done with Jegs push-lok stuff and I've had no problems with it.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #7 of 14 (permalink) Old 03-14-2008, 11:42 AM
Deputydog's Avatar
Re: Hose ?
Dan
I got mine from www.arizonatpi.com call them on the phone and tell them you want the GSL 392 and say "EFI components" and they will sell it to you for $99..
I installed my Walbro and it works great. Installed in the stock location and used stock wiring.
post #8 of 14 (permalink) Old 03-14-2008, 04:03 PM Thread Starter
skylinedan's Avatar
Re: Hose ?
Thanks I,ll do that when I get a chance. I read that somewhere on here awhile back , remember the thing about saying EFI componets.
Dan
post #9 of 14 (permalink) Old 03-14-2008, 05:04 PM
Banned
Send a message via Yahoo to blk99
Re: Hose ?
Jegs has there "Push-Loc" and Russel has the "Twist-Loc"...
I like Jegs Push-Loc cause I can get it in RED!!!
blk99 is offline
post #10 of 14 (permalink) Old 03-14-2008, 09:41 PM Thread Starter
skylinedan's Avatar
Talking Re: Hose ?
I have one of their catalogs , but I did,nt see anything like that. Do I need to call them.
Dan
