bad day - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 03-12-2008, 11:18 PM Thread Starter
fordtrucksrule7's Avatar
bad day
went to install itp overboost annihalitor and took the old hose off the map sensor and part of the map sensor came with it so i glued it back on and of course it doesnt hold just broke off like nothing also my tube seems to short going from the turbo to the map sensor mounting location does the early 99 need to be longer. i havent ran it yet so will it run normal without it being hoooked up or will it be all messed up since it doesnt think its got any air. thanks and is powerstrokeshop the cheapest place to get it
fordtrucksrule7 is offline
post #2 of 15 (permalink) Old 03-12-2008, 11:32 PM
Haul_n_horses2's Avatar
Re: bad day
Yes and they are not too pricey.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #3 of 15 (permalink) Old 03-13-2008, 12:02 AM
Send a message via AIM to JohnT
Re: bad day
It shouldnt be too short. It fit on mine.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #4 of 15 (permalink) Old 03-13-2008, 12:25 AM Thread Starter
Re: bad day
was it tight or did it have some play in it
post #5 of 15 (permalink) Old 03-13-2008, 12:38 AM
you want some of this?
smorris's Avatar
Re: bad day
It'll cut back on the power if its unhooked. Minegot disonnected when doing some stuff, and it still started and ran fine. But when I hookked it back up it was a lot stronger. If the map doesnt see boost, it doesnt add the fuel like its supposed to. On the upside, there was no smoke at all from the tailpipe.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #6 of 15 (permalink) Old 03-13-2008, 12:43 AM
Deputydog's Avatar
Re: bad day
I've got a spare map sensor if you want it.
Deputydog is offline
post #7 of 15 (permalink) Old 03-13-2008, 02:18 AM Thread Starter
Re: bad day
yea i took it for a spin and could only get 20psi and not hte power it normally has
dang i already ordered one from powerstrokeshop but thanks alot i appreciate it, and thanks for all the help
post #8 of 15 (permalink) Old 03-13-2008, 01:57 PM
Sleep well my brothers
yamt03's Avatar
Re: bad day
My hose was too short as well. I used part of my stock hose from the Y to the MAP & part of the ITP O/B hose connected it together with a T for my boost gauge and it has been working with no problems.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #9 of 15 (permalink) Old 03-13-2008, 02:03 PM
yamt03's Avatar
Re: bad day
Oh and try not to run the truck too much with it not connected. My buddy drove his for like a week not knowing it had popped off and he had to replace a few things because of it not being connected. I don't remember what the dealer had to replace but he told me they replaced a couple of things. And he's finally a member here so maybe he will read this and chime in,but I wouldn't hold my breath waiting on him.
yamt03 is offline
post #10 of 15 (permalink) Old 03-13-2008, 04:05 PM
Village Idiot
southmike's Avatar
Re: bad day
sooo in hind site would you do it again like that , just being a lil more careful
or just cut the hose and put a tee in.
southmike is offline
