43psi of boost.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 52 (permalink) Old 08-11-2007, 06:03 PM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
43psi of boost....
Means blowing my head gaskets and filling god knows what with 5 gallons of coolant!!!!!!!!!!!!!!
What should I do next.......comeics and studs are going on....thinking about firerings (maybe). should I get the heads worked on while I have them out. push rods..??? My motor has 220,xxx miles not sure what else to look into while I'm in there.
lildevil02 is offline
post #2 of 52 (permalink) Old 08-11-2007, 06:41 PM
BLCKOUT
bigcountry250's Avatar
Send a message via AIM to bigcountry250
Re: 43psi of boost....
Really sorry to hear about all this Gabe! You'll get her running great again don't worry, stuff happens!
2011 CC SB 6.7L Powerstroke
BLACKOUT.... gone but never forgotten!!
bigcountry250 is offline
post #3 of 52 (permalink) Old 08-11-2007, 08:41 PM
WHAT???
STROKIN N STYLE's Avatar
if you put cometics on there i would have the head re-decked to insure full coverage. pushrods and stiffer valve springs probly wouldn't be a bad idea either, before i did that i bent 2 pushrods in 2 weeks.
2000 F-250 ex sb 4x4 Swamped 7.3 (CR coming soon)
1999 F-450 cc fb 4x4 Swamped 7.3 (STOLEN)
2008 F-250 cc sb 4x4 H&S, S&B, 5", BMF, Grabbers
STROKIN N STYLE is offline
post #4 of 52 (permalink) Old 08-11-2007, 11:56 PM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
what size cometics do I need? I am not going to be adding anything powerwise...if that helps any.
post #5 of 52 (permalink) Old 08-11-2007, 11:58 PM
If you use cometics, the block and heads need to be PERFECT.
I would go stock HG's and studs personally.
gregrob is offline
post #6 of 52 (permalink) Old 08-12-2007, 12:14 AM
DarkShadowDiesel's Avatar
fwiw elmo is running stock gaskets and studs if i'm not mistaken
2002 F250
DarkShadowDiesel is offline
post #7 of 52 (permalink) Old 08-12-2007, 12:23 AM
HP Junky
I think stock gaskets and h11 studs have been proven upwards of 55-60psi. Thats the route I went.
RockinJW is offline
post #8 of 52 (permalink) Old 08-12-2007, 01:25 AM
WHAT???
i've got stock gaskets with studs and i'm running a little over 60psi on top end and haven't had any problems, just bent a couple pushrods, but thats fixed now.
post #9 of 52 (permalink) Old 08-12-2007, 01:32 AM
Banned
Depends. Stock "Virgin" gaskets with over 150,000 or so miles on them are basically the strongest material on the face of the planet when combined with headstuds. They will fair much, much better than the rods and likely the block.
You have to be careful when running brand new ones though. They tend to spit out when freshly installed. They seem to like some miles on em before they start to turn into unobtanium.
If I ever have a gasket issue, I plan to run the stock thickness Cometics and a set of Cuninghams (since Hypermax rods are non-existent nowadays). And that's it. Maybe fill the block a tad and toss some studs in the mains. I feel that should be fine for mid 800's on fuel with daily reliability. 1000 if you wanted to push things.
Two Cents
Charles is offline
post #10 of 52 (permalink) Old 08-12-2007, 11:01 AM
Haul_n_horses2's Avatar
I thought Hypermax had a new set of rods in production. I know Brian T bought a set and he said they were beautiful.. Very evenly balanced and light.
Haul_n_horses2 is offline
