single shots yes or no? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 61 (permalink) Old 03-12-2008, 02:52 AM Thread Starter
Got 'Er Did
lownslow's Avatar
i there some reason why not so many people run single shot injectors?
maybe i am confused but wouldnt they be worth it beins not havin to run big oil? or did i miss something?
2009 Mustang GT Premium 5spd
BBK Long Tube Headlers and Off Road X Pipe
waiting for the squeeze
1995 F350 Crew Long 4x4 Dually
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #2 of 61 (permalink) Old 03-12-2008, 02:55 AM
00PSD1's Avatar
Re: single shots yes or no?
I think most people run single shots. Its the splitshots you need to stay away from.
Single shots seem to get better MPG and run better then splits
00PSD1 is offline
post #3 of 61 (permalink) Old 03-12-2008, 03:03 AM
Dieselgeek's Avatar
From what I understand they are a bit louder at idle, but yes, consume less oil, and usually gain mpg. If and when I decide on injectors, I'm gonna run singles...
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
post #4 of 61 (permalink) Old 03-12-2008, 05:36 AM
Freedom is not free
White Buffalo's Avatar
Yep, I run the 175/146 single shots from swamps, no need for big oil since they use less oil and added about 50-60 hp. I bit noisier at idle, but the same noise level on highway. 17-18 mph highway, 15 around town -with a heavy foot.
White Buffalo is offline
post #5 of 61 (permalink) Old 03-12-2008, 05:47 AM
Banned
Send a message via Yahoo to blk99
singles are what the stock OBS has and splits are the stock SD's....
singles get better milage because they dont shoot that extra shoot of fuel (hence names.... single shot....split shot... )
singles are a little louder because they dont have that extra shot.... I believe that is the only reason for the extra shot... quietness...
The bigger single shots will still need BO (i.e. B-codes) but stage 2 and down they should run fine with without BO because they dont need near as much pressure to inject the fuel efficiently (again, because of the lack of the extra shot of fuel)...
blk99 is offline
post #6 of 61 (permalink) Old 03-12-2008, 08:28 AM
Who said they didn't need big oil
160cc AD singles use about the same oil as a stock AD split, and YES a stock AD split shot needs oil to maintain ICP with aggressive programming and get everything out of the injector.
Sure you can run 160cc singles, or 180, or whatever you want without big oil. But will they perform the their potential, absolutely not. Just like the stock HPOP is not usually capable of maintaining respectable ICP levels with stock injectors.
I have ran 180cc singles before big oil, and after big oil. If I had to take either the injectors or the pumps back to stock it would be the injectors. They made a difference in the way the truck ran but NOTHING like the pumps did. They really brought it all together and made the thing pull, when before it just revved and made a lot of noise.
gregrob is offline
post #7 of 61 (permalink) Old 03-12-2008, 04:53 PM
Freedom is not free
I said it....
For my setup it doesn't look like I need big oil. My Stock HPOP at 101,000 miles is holding pressure pretty good for this test if I data logged this correctly (only my 2nd time).
This was on my tow setting:
Started data logging at 70 mph, punched it.....hit 100 after 10 secs, she kept accelerating after that.
post #8 of 61 (permalink) Old 03-12-2008, 05:49 PM
Needs more hours per day
jtharvey's Avatar
Reduced noise is what I've always heard and been told was the reason for a split shot design.
Seems to me that a little bit of injector control would be lost with splits, because if I understand it correctly the split shot is done mechanically in the injector. Single shots take away one area that we have no control over -- the length of time between when the injector is told to fire and the main shot actually starts, since the little shot has to go off first. And, I believe this is also the reason programming has to be changed when switching from splits to singles, to adjust injector timing.
With that said, I'm quite happy with my single shots. No desire to have the splits back.
Rich, that's pretty impressive for a stock HPOP. What were the duty cycle numbers?
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #9 of 61 (permalink) Old 03-12-2008, 07:31 PM
Freedom is not free
Jeremy,
The duty cycles #'s ranged from 40.62 to 42.58 during the 2 to 40 seconds time frame on the graph. You can barely see the duty cycle line at the bottom of the graph, should I graph them seperately next time?
post #10 of 61 (permalink) Old 03-12-2008, 09:23 PM
ERJ Aircraft Mechanic
Tail_gunner's Avatar
The move to splits was originally an emissions thing.
Singles do make more noise than splits, but for a given amount of HPOP, singles make more HP & MPG than splits, all other things being equal.
If there is one reason why more people don't go with singles is the need for new tuning to get the singles to idle smoothly in a 99+ engine.
Kent
FAA Certificated Airframe & Powerplant Mechanic
USAF MSgt (Ret.)
B-52 Gunner, 3600+ Hours
B-52 crew chief
SOLD: Early 99 F-250, 99.5 PCM, Single Shot Stage I's, Power Hungry Perf, Dominator 66 Turbo, Adrenaline HPOP, 6.0 Intercooler, Trans by BTS, MBRP 4" exhaust, 99.5+ intake covers, Hutch Mod, KCM H/X, Dynatrac. 0-60 < 7 sec's.
Tail_gunner is offline
