How Much Smoke... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 53 (permalink) Old 03-11-2008, 07:38 PM Thread Starter
2000 F350 SuperDuty 4x4
Calico5's Avatar
How Much Smoke...
I finally got around to installing the Stage II single-shots, and had Jody burn me a PCM & chip for them. Been running them for a week or so and...DAMN do they put out some smoke!
How much smoke should I expect from these? Right now, they haze pretty good even in the "stock" setting, and in "140"...the sun disappears, along with anything behind me.
The stock AD's with (basically) the same tunes didn't smoke near as much as these, and the bottom-end/mid-range power seems down a bit also, although the top end is better, with a few more PSI of boost at WOT.
I'm putting in a mechanical HPOP guage next week, so I'll have some readings to share. The rest of my Mod's. are in the sig.
Any thoughts or comments?
Thanks in advance to all...
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #2 of 53 (permalink) Old 03-11-2008, 07:41 PM
Banning Smut
PTSUPERD's Avatar
Re: How Much Smoke...
My 38r manages to clean up most of the smoke from my hybrids (with aggresive tuning). I'm very surprised your 38r doesnt clean up the fuel on a set of stage 2s........hmm
now dont get me wrong, on a really hot setting mine will roll coal.
what file is it? 140?
PTSUPERD is offline
post #3 of 53 (permalink) Old 03-11-2008, 07:46 PM Thread Starter
Calico5's Avatar
Originally Posted by PTSUPERD View Post
My 38r manages to clean up most of the smoke from my hybrids. I'm very surprised your 38r doesnt clean up the fuel on a set of stage 2s........hmm
That's what I said...hmmm.
I've double checked for any leaks (exhaust and intake side) and eveything's in good shape.
I was on a local highway, and with the cruise set at 75 mph, as I started up a 5-6% grade, I was very lightly hazing smoke. I was suprised to say the least. Never saw that before with the other sticks.
How much peak boost pressure are you seeing with the 38r and hybrids?
Al in SoCal
Calico5 is offline
post #4 of 53 (permalink) Old 03-11-2008, 07:49 PM
Starting Over
kainers's Avatar
Maybe you got a set of Big boys by mistake
Nozzle size will have an effect on smoke levels
kainers is offline
post #5 of 53 (permalink) Old 03-11-2008, 07:51 PM Thread Starter
Calico5's Avatar
Well...maybe. I got 'em from CSIPSD. They were what he was running prior to goin to the hybrids.
You out there CSI? Maybe you can chime in here...
Al in SoCal
Calico5 is offline
post #6 of 53 (permalink) Old 03-11-2008, 07:57 PM
Banning Smut
PTSUPERD's Avatar
Peak boost for my setup is generally 40 psi. I've seen 42 on occasion.
PTSUPERD is offline
post #7 of 53 (permalink) Old 03-11-2008, 08:05 PM
Haul_n_horses2's Avatar
I can smoke out the intersection with my DDP nozzled AC singles and any of my tunes until the H2e spools, then it will clear but my biggest program is 80 hp until the forged rods are in place. I am going to be live tuned in May to help out on smoke and mileage. I used to get 15-16 mpg around town and rural driving at 50/55 mph but now the best I can do on the freeway at 65 mph is 14 mpg.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #8 of 53 (permalink) Old 03-11-2008, 08:29 PM Thread Starter
Calico5's Avatar
Does DDP modify the AC's, or are they "stock"?
I was also getting about 15-16 mpg (combined city and hiway). I haven't ran any milage numbers yet, but I think mine's gone down a bit also.
Thanks...
Al in SoCal
Calico5 is offline
post #9 of 53 (permalink) Old 03-11-2008, 08:45 PM
What nozzle size and what's your ICP at WOT? Stage 2 singles should be right around 41 lbs and splits were around 38 lbs(DP Tunes).
TerminatorEngineering is offline
post #10 of 53 (permalink) Old 03-11-2008, 08:58 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I saw between 35-38psi with those stage 2's. They are swamps 175/173's, I never flowed them but they should be in the 180 range. There not a big set of stage 2's by any means???
Joe
CSIPSD is offline
