Stupid ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 38 (permalink) Old 03-11-2008, 03:10 AM Thread Starter
cota's Avatar
Stupid ?
Kinda got a little hooked at the drags the other night, what does it take HP wise to drop 3/10s, or get under 13's,seriously. Thanks
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #2 of 38 (permalink) Old 03-11-2008, 03:17 AM
Re: Stupid ?
You might be able to drop the time just by tweaking your current setup. Talk to your tuner and find out if there is any fuel left. Get your suspension dialed in and get sticky tires. Also spending more time at the track and getting your reaction times, etc. dialed in helps.
69W900A is offline
post #3 of 38 (permalink) Old 03-11-2008, 03:25 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Re: Stupid ?
Put the truck on a diet. Take everything out or off that you don't need. Cut down on your fuel level - not a full tank. Leave your tools, spare and tailgate with a buddy while you run. Every couple hundred pounds you can shed make a difference.
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #4 of 38 (permalink) Old 03-11-2008, 03:29 AM
OEM Moderator
Tom S's Avatar
Re: Stupid ?
Just a really good launch might make a nice difference too. Do they have any test and tune nites near you?
Tom
Tom S is offline
post #5 of 38 (permalink) Old 03-11-2008, 03:29 AM
Starting Over
kainers's Avatar
Re: Stupid ?
Yep weight will make a difference.That fuel tank in the bed had to cost you some ET.
kainers is offline
post #6 of 38 (permalink) Old 03-11-2008, 03:33 AM Thread Starter
cota's Avatar
Re: Stupid ?
Yea a few more runs to find out best launch method would help a lot and shedding weight should be simple, get rid of the 110 gallon tank in the back, spare tire, tools, one battery and half tank of fuel, check, check, double check. Hard to get better tuning over the phone though, live tuning would be awsome and need to do something about ICP, was a bit low at 2400 at 37.5 duty cycle. Did I mention that was way fun.
2000,CC,4x4,auto
cota is offline
post #7 of 38 (permalink) Old 03-11-2008, 03:34 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Stupid ?
You have a good set up... I can E-mail that Excel file to you and you can send it to cale or who ever you want...
Joe
CSIPSD is offline
post #8 of 38 (permalink) Old 03-11-2008, 03:38 AM
Sponsor
airflo71's Avatar
Re: Stupid ?
Cota is hooked...No turning back now...Welcome to the darkside...
airflo71 is offline
post #9 of 38 (permalink) Old 03-11-2008, 03:38 AM Thread Starter
cota's Avatar
Re: Stupid ?
I'll give him a call and see what he has to say. Thanks very much for the help. Maybe 12's arn't so far away.
2000,CC,4x4,auto
cota is offline
post #10 of 38 (permalink) Old 03-11-2008, 03:41 AM
Starting Over
kainers's Avatar
Re: Stupid ?
12's are very easy for you.I bet you could do it with just a diet.That track had some serious traction issues especially the rt lane.
kainers is offline
