Seal the compressor cover? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-09-2008, 08:47 PM Thread Starter
Cummins Power
mech2161's Avatar
Most turbos I've handled the compressor side fits fairly loose. Has anyone tried to seal the cover to the center? These turbos weren't originally designed for the pressures were running them at so it probably wasn't a big deal. Any thoughts?
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #2 of 14 (permalink) Old 03-09-2008, 11:53 PM
Re: Seal the compressor cover?
free bump.
I'm interested in this info also. As i have seen them with no seal, or with some type of silicon.
Andy
I would like to thank F.A.S.T. for helping with the 2008 pulling season.
For all your fire service repair and fabrication needs. Will travel.
IDM Info Updated 11/07/08
mustang_gt_350 is offline
post #3 of 14 (permalink) Old 03-10-2008, 02:41 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
If your refering to your S4 you got, then don't worry about it. Just clock it and tighten the V-band or cover bolts
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #4 of 14 (permalink) Old 03-10-2008, 02:49 AM Thread Starter
Cummins Power
mech2161's Avatar
Not any charger in particular. The compressor housings are not a tight fit and could leak at high pressures.
Kevin
mech2161 is offline
post #5 of 14 (permalink) Old 03-10-2008, 03:03 AM
How much pressure are you running that you are worried about it?
-Michael
Michael
post #6 of 14 (permalink) Old 03-10-2008, 03:08 AM
<- Sums it up
strokin_early_99's Avatar
My modded H2E is a very nice close fit but it is also only a v clamp without any seal. I figured if a seal is needed then Chris would have added it when he modded my H2E.
So, mine does not have a seal and it holds 53-54psi. Not that I would know if it it is leaking. I don't know anybody that would stick their head into under the hood while it is on a dyno to check it with soapy water.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #7 of 14 (permalink) Old 03-10-2008, 03:10 AM
My modded H2E has been to 60psi, like I said I'm not worried about it.
-Michael
Michael
post #8 of 14 (permalink) Old 03-10-2008, 03:24 AM Thread Starter
Cummins Power
mech2161's Avatar
If your not worried about it thats fine.
This is my point. Lost pressure is potentially lost power.
Kevin
mech2161 is offline
post #9 of 14 (permalink) Old 03-10-2008, 03:55 AM
Needs more hours per day
jtharvey's Avatar
Admittedly, I haven't seen many turbos apart except for the stock/van turbo, but I would have thought there's some kind of seal. The stock ones do have that big o-ring around the compressor backplate, but they don't see the same pressures larger turbos do, and with a fitted, non-clockable housing, it will attach differently too. Interesting thought Kevin. I'm curious too now.
I'm wondering if the expansion of metal due to heat doesn't create a tight enough seal to not leak? Turbos are assembled at room temp, yet get heated up when the truck runs. The compressor side can heat up the air to what, 400*? How much of that heat get's transferred to the housing?
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #10 of 14 (permalink) Old 03-10-2008, 05:54 AM
<- Sums it up
Kevin, I would talk to your sponsor since he provided the turbo. If there is a seal or way to seal then he should be the one that would know.
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
