Non-ebpv pedistal going on soon, what do I do with the electricals - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-08-2008, 08:49 PM Thread Starter
What to do with the sensor? I imagine I will get a code. Is this a problem, or is it just like the AIH delete? Thanks
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #2 of 11 (permalink) Old 03-08-2008, 09:00 PM
rebelchevy02's Avatar
Re: Non-ebpv pedistal going on soon, what do I do with the electricals
Mines an 02, and mines been unhooked for over a year. No check engine light, but the passive code comes right after the start. Hasnt bothered me a bit though, its just unhooked laying in the valley of death.
DRW and tow fast parts.......
rebelchevy02 is offline
post #3 of 11 (permalink) Old 03-08-2008, 09:26 PM
Orezona's Avatar
This is what I used on my 02 http://www.puredieselpower.com/catal...tor-p-106.html
Orezona is offline
post #4 of 11 (permalink) Old 03-08-2008, 11:51 PM
Haul_n_horses2's Avatar
It isn't a problem. I put the SPDiesel dongle on and it still threw a code. Pulled the dongle and connected the sensor. I get a code but it is not a problem. Allows me to monitor back pressure with AE. Called Sean about the code with the dongle and it was coming from the disconnected EBPV solenoid. He said he could make a dongle for that too. I said F**k it.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #5 of 11 (permalink) Old 03-09-2008, 12:52 AM
Send a message via AIM to JohnT
I gutted my pedistal myself, and thought that if i plugged the sensor in, it would not throw a code. That idea was shot, it still throws the code. I would just leave it lay there. It throws a soft code, which you wont see unless you scan for codes, and it does not affect anything except that backpressure valve, which you no longer have.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #6 of 11 (permalink) Old 03-09-2008, 01:22 AM Thread Starter
Thanks guys, you saved me 40 bucks plus shipping. Should I lather it up with a little dialectric grease and let it dangle or just leave it. I don't think that I will ever use it again, but I would like to preserve it just in case.
BTW, it seems like a lot of these dongle things don't work and still throw codes.
post #7 of 11 (permalink) Old 03-09-2008, 03:17 AM
I didnt do anything with the connector, I just let it sit there. Just recently I was redoing the mount for my fuel pressure regulator and happen to look at the connectors, still looked like i unplugged them 6 months ago, I would just let them hang, if you are going to put the truck back to dead stock one day, then i would just put a little bit of electrical tape on the end to prevent crap from getting in the connector.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #8 of 11 (permalink) Old 03-09-2008, 03:32 AM
OEM Moderator
Tom S's Avatar
You could get a weather pack connect and fill it with some rtv and cap it that way. You can also get weather pack plugs to put in a connector too if you wanna get fancy.
Tom
Tom S is offline
post #9 of 11 (permalink) Old 03-09-2008, 04:12 AM
I just let mine hang. As much trouble as my sticking ebpv caused me, i dont care if the connector wrotted off. Its gone, period. If you want to hook it up again, cover it up somehow.
post #10 of 11 (permalink) Old 03-09-2008, 07:09 AM
Dieselgeek's Avatar
Mine is laying in the valley...
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
