EBPV Brake Instructions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-08-2008, 03:50 AM Thread Starter
Deepsky3539's Avatar
Been reading a lot about the EBPV brake and did quite a bit of searching but could not find anything on how to actually do it . Any good links you guys know of?
I looked at Guzzle's page and the TC Lockup looks super easy but I was wondering why you wouldn't just tie the switch for the brake and the TC Lockup together. Let me know where I am going wrong on this.
Thanks in advance.
2001 F250 Extended Cab 4x4
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Magnaflow 4" Exhaust
Turbomaster Wastegate Controller
Dieselsite engine and intercooler boots
Pricol Optix gauges
DP Tuner= No Start, Stock, 80 Econo, 40 HA Tow, 140 Race
Lots-o-surge
Deepsky3539 is offline
post #2 of 13 (permalink) Old 03-08-2008, 03:30 PM
Village Idiot
southmike's Avatar
Re: EBPV Brake Instructions
diy brake
http://www.swamp-donkey.biz/
go to How-Tos & FAQs
there are a couple of others...but i don't remember them.
southmike is offline
post #3 of 13 (permalink) Old 03-09-2008, 05:37 AM Thread Starter
Thanks ... I looked at quite a few that I did eventually find by searching the web and I think I am definitely going to do a modified version of Swamp Donkeys design becaue I love the brake pedal design. I do however want to lock up the TC without closing the EBPV, so I will have to do a little more design work.
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Pricol Optix gauges
Lots-o-surge
post #4 of 13 (permalink) Old 03-09-2008, 06:37 AM
Send a message via AIM to JohnT
I made(well actually my buddy made it, im not that good at electrical), the TC lock up box from guzzles site. It worked very well.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #5 of 13 (permalink) Old 03-11-2008, 02:49 AM Thread Starter
I have done a little re-design and will be posting it after this coming weekend. Basically, the original design from Swamp Diesel didn't light up in position 2 until the brake pedal was depressed. I decided that I wanted to know before I hit the brake that I was in mode 2. It required a couple of more diodes (another $1.99) but it should work. I will post the circuit design and talk about results when it is finished. Stay tuned.
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Pricol Optix gauges
Lots-o-surge
post #6 of 13 (permalink) Old 03-11-2008, 02:59 AM
All done now
Arisley's Avatar
Cool.
Arisley is offline
post #7 of 13 (permalink) Old 03-12-2008, 04:20 AM Thread Starter
OK ... Installation is this weekend (or after work if I get antsy). Here are two updated diagrams. The first one is complete while the second one has the LED's removed so it is a little more clear on the function. The point here is to have the LED's for mode 1 and mode 2 be solid on when in that mode instead of the LED only going off when the brake is depressed in mode 2.
If anyone see's any issues let me know. My only concern is the .7 voltage drop across the diodes to the TC. It shouldn't be an issue but you never know. I also do not know if this design will cause the Overdrive light to flash. If that turns out to be an issue, I can always add a relay and do something like Guzzle did.
It just dawned on me a few minutes ago that I did not add the diodes to the drawing that go to the EBPV. I will update the diagram and re-upload it.
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Pricol Optix gauges
Lots-o-surge
post #8 of 13 (permalink) Old 03-13-2008, 12:18 AM Thread Starter
This should look better.
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Pricol Optix gauges
Lots-o-surge
post #9 of 13 (permalink) Old 03-16-2008, 12:19 AM Thread Starter
I thought I had enough time to put this in today but between snow flurries and realizing I was going to have to pull an intercooler pipe to get to it, I did not. I thought it was easier to get to than that. I will have to try and either find another warm "Full" day or get a heated garage.
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Pricol Optix gauges
Lots-o-surge
post #10 of 13 (permalink) Old 03-16-2008, 10:59 PM
Above It All
Cool Canuck's Avatar
With an '01, I would worry about the lockup. Earlier trucks would unlock with brake application. Yours don't. Your good down to about 35mph.
'01 F250 SC/SB 4X4 Trailer Tug
Cool Canuck is offline
