H2E mounting flange - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-10-2007, 07:36 AM Thread Starter
<- Sums it up
strokin_early_99's Avatar
H2E mounting flange. T3 or T4??
Does the H2E use an T3 flange or a T4? Looking for a mounting arrangement that will grow with me. Possibly something like a GT40R that uses a T4 or large for next pulling season.
Come on Guys, help me out.....
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #2 of 6 (permalink) Old 08-10-2007, 10:55 PM
Re: H2E mounting flange
I believe the H2E uses a T3 flange. It does not use the large flange (T4) like the K31/GT42, etc. use.
69W900A is offline
post #3 of 6 (permalink) Old 08-11-2007, 12:52 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
It's slightly bigger or smaller than either t3 or t4, I know a lot of help huh, ask bean he knows for sure.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #4 of 6 (permalink) Old 08-11-2007, 03:32 AM
Powerstroke Racer's Avatar
K31 and H2E are the same flange, bigger than a T3 same size as a T4 just wider in the bolt holes.
Powerstroke Racer is offline
post #5 of 6 (permalink) Old 08-13-2007, 01:58 AM
94ttss's Avatar
The H2E is neither a t-3 or t-4 flange. It is very close to a t-4 in size but the bolt holes do not line up. The k-31 as it comes from Borg Warner has a t-6 flange. The easiest way to get one would be to just cut one out of 1/2" cr plate
Kai
'02 F-350 CC/SB XLT
Cummins 5.9 ISBE Common Rail
Sticks by F1
Twin Turbos by Me
Fuel by Me
BTS
12.3 @ 109mph #2 only 9/13/08
94ttss is offline
post #6 of 6 (permalink) Old 08-13-2007, 02:46 AM
Banned
Here's the flange I made for the 47. It's 1/2" "wear plate" I got for free at the local welding shop. No fancy tools, just a sawzall for the cuts and a hand grinder to round the corners. Used the drill press for the holes and the steel gasket to center punch em. A little love with the stick welder and it was hangin under the hood.
http://rides.webshots.com/photo/2919...82519711uvihDH
If you can have access to an engine sitting on a stand, you can mock it all up without having to take the truck down while you fab it. Really helps if you're working on a true daily driver.
Good Luck.
Charles is offline
