valve springs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-13-2010, 01:05 AM Thread Starter
valve springs
How exactly are you guys doing them? I am about to do the comp 910's when I swap injectors. I understand you use the glow plug hole to put pressure in the cyl. What size is the glow plug hole so I can find my correct air fittings? And should the injector be in or out? how much pressure should you apply. 100-120 psi?
Thanks!
no-tel-in is offline
post #2 of 13 (permalink) Old 09-13-2010, 01:15 AM
Pearson's Diesel
smokin dually's Avatar
Re: valve springs
You can get the pistons top dead center and use them to hold the valves up. Thats how I did them.
01 F350 cc dually 6sp conversion
00 F250 2.6 puller
early 99 F350 2wd daily driver
smokin dually is offline
post #3 of 13 (permalink) Old 09-13-2010, 01:15 AM
I like turtles
NE-STROKE's Avatar
Re: valve springs
Injector can be in. Otherwise air would leak out. I used the glow plug hole and mad a adaptor to run air in. I came up with the perfect tool to do this. Go to local harware store and buy a greae gun hose. The one end has same threads as a glow plug. Then go to pipe and fitting section and convert it up to a air chuck fitting. Worked awesome.
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #4 of 13 (permalink) Old 09-13-2010, 01:32 AM
TARM's Avatar
Re: valve springs
MAr4ty had a greaty video he made that went over step by step doing the valves and a number of toehr things. I checked the link and its now broken or passworded.
Marty,
Anyway you could do an updated links to those videos as they sure are helpful for people doing this stuff for the first time. Or is there an updated post or thread with them?
This thread Maintain's Install Info..lots of good stuff here!! - Powerstroke Nation
TARM is offline
post #5 of 13 (permalink) Old 09-13-2010, 01:40 AM Thread Starter
Re: valve springs
I KNOW, I tried watching Marty's vid and noticed it was broken about 2 weeks ago, I've been meaning to get in touch with him anyways
post #6 of 13 (permalink) Old 09-13-2010, 01:43 AM Thread Starter
Re: valve springs
Sounds good man... 100 or psi, right?
post #7 of 13 (permalink) Old 09-13-2010, 01:53 AM
I like turtles
NE-STROKE's Avatar
Re: valve springs
I think I had mine set at 90. I still put motor on top dead center to be safe. Make sure you have a small magnet on hand to
post #8 of 13 (permalink) Old 09-13-2010, 02:12 AM Thread Starter
Re: valve springs
oh yeah, not taking any chances there
post #9 of 13 (permalink) Old 09-13-2010, 02:20 AM
Re: valve springs
I just put them at TDC and didn't use any air. Just make sure and rotate the motor for every cylinder and take your time.
bigjake0524 is offline
post #10 of 13 (permalink) Old 09-13-2010, 03:47 AM
Re: valve springs
how do you check to make sure there is 125lbs of seat pressure?
2K Excursion, AFEII intake, 4" straight exhaust, DP F6, 200cc singles, 38R, RR, T500, ATS stage II with 5 star tc
Balthasar is offline
