Installed my 71 mm H2E kit tonight - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 66 (permalink) Old 02-28-2008, 03:25 AM Thread Starter
matthewd11's Avatar
This is the sledscreamer 71/17 H2E. What a pain it was to get the old stainless exhaust off (only put on 2 months ago!) I had to cut it with a torch. Anyway, install went OK. Everything came off within 45min to 1 hr excluding the exhaust (took another 45-1 hr). The pedastal was a little bit of a pain, i had to bend the fuel line going to the back of the passenger side head. Up pipes were EASY. I was very surprised how easy it was. No more exhaust smell out side of the truck! (carquest 3$ gaskets). Turbo bolts were easy except 1, which was the top right bolt when looking at the front of the truck. I could not get any wrench or socket in there, so it is only finger tight. All the other ones are TIGHT. i made sure of that. CAC tubes were a snug fit, had to really push to get them on.
On to the fun part:
On the the first test drive the SES light was on, and i forgot to plug in the map sensor Second test drive all was well except now i'm setting my P1211 code in my 100 hp tune but a new IPR is on the way, as this one has never been cleaned/changed since 2000. Hopefully that will help some. Turbo lights around 1850-1900 RPM in my 80 tune (does that seems right?) with stock injectors and builds boost quickly after that. Peak is in the high twentys low thirty range, but i didnt stay in it for that long, as i was trying to watch for the LEOs.
To make a long story short, very happy with the turbo, sounds ALOT better than the stocker, lag isnt awful, but noticeable difference from stock with .84 housing (obviously). Everything took about 5-6 hours to install (all because of that damn exhaust).
BTW, anyone need a good stock turbo + everything else turbo related from 2000 truck
matthewd11 is offline
post #2 of 66 (permalink) Old 02-28-2008, 03:55 AM
Stupid Kid
Re: Installed my 71 mm H2E kit tonight
Thats a big turbo for a stock injectored truck.
thedieselkid is offline
post #3 of 66 (permalink) Old 02-28-2008, 04:20 AM
What else?
smokyred's Avatar
I would agree with the above statement, then again, looks like he's prepping for those stage III's.....
Dave
smokyred is offline
post #4 of 66 (permalink) Old 02-28-2008, 04:34 AM
airflo71's Avatar
Get some big fuel in there, a 71mm is huge for stock injects, heck a 64mm is large for stock, you should spool at 1200-1350, at 1850 more than half your usable RPM band is gone.
airflo71 is offline
post #5 of 66 (permalink) Old 02-28-2008, 04:41 AM
<----Colin Banks
mattymx's Avatar
He is doing it right with the turbo first. This way his stock turbo is still in good shape to sell so he has to put up with a little lag until he gets the hybrids in.
mattymx is offline
post #6 of 66 (permalink) Old 02-28-2008, 04:42 AM
Starting Over
kainers's Avatar
I light right at 1600 or so.Same turbo.I push 40 psi easy in the tow.Hybrid inj's though with mild tips so they say.
kainers is offline
post #7 of 66 (permalink) Old 02-28-2008, 04:47 AM
well you better post some vid's after each mod is installed. that way you can look and see how much faster each mod made you
SuperStroker10 is offline
post #8 of 66 (permalink) Old 02-28-2008, 04:49 AM
airflo71's Avatar
Better to get the air in then add the fuel, but man if my turbo lit at 1850 I would be keeping my truck in 3rd gear all the time just trying to get boost.
airflo71 is offline
post #9 of 66 (permalink) Old 02-28-2008, 04:51 AM
Laces Out
bigrpowr's Avatar
i have to ask, what turbo spools at 1200 rpms? isnt usable rpm more like 1600- 3200?
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #10 of 66 (permalink) Old 02-28-2008, 06:28 AM
what kind of boost are you pushing at WOT
