Ceramic coating - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-09-2007, 03:34 AM Thread Starter
Stupid Kid
Ceramic coating
Is it really worth it. If I do it I will do manifolds, uppipes collector and the turbo. It would be nice if it helped spool up does it really make much of a difference. But the main thing that I am wanting is the reduction in underhood temps. If I pop the hood after driving I can't touch nothing for aat least a half hour with it burning, well not burning, but very uncomfortable you know what I mean. And do they just coat the outsides of everything or do they do everything inside and out.
thedieselkid is offline
post #2 of 14 (permalink) Old 08-09-2007, 03:36 AM
Laces Out
bigrpowr's Avatar
Re: Ceramic coating
yes its worth it!!
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #3 of 14 (permalink) Old 08-09-2007, 03:38 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Re: Ceramic coating
All the BWD stuff says it's coated with 2000* stuff inside and 1600* on the outside. So I would say yes you can get both the inside and out side coated to get the most out of it.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #4 of 14 (permalink) Old 08-09-2007, 03:45 AM Thread Starter
Stupid Kid
Re: Ceramic coating
How do they coat the insides of stuff. I don't see how it could really be sprayed to well, and dipping it would make it run and be a waste of coating is there another way of doing it.
post #5 of 14 (permalink) Old 08-09-2007, 03:55 AM
Re: Ceramic coating
If you do not have the inside coated as well as the outside they will rust from the inside out. Speaking from experience here.
JMS1 is offline
post #6 of 14 (permalink) Old 08-09-2007, 04:15 AM
Banned
Re: Ceramic coating
If you only chose to coat one or the other, you would only coat the inside, not the outside.
They use all kinds of tricky chit to coat the insides. Let it run down, run the nozzle way down in the port/tube. A company local to me coated the insides of my manifolds (insides only) to keep the heat out of the actual manifold material and save them from warping, expanding, shearing bolts and cracking like they were.
So far I've swapped out the driver's side with the internally coated one. After driving for a couple weeks it still doesn't look like it's been run yet from the outside
There is just no heat coming through now.
I have read data about some testing done on an engine producing around 1530 degrees egt. With a laser Thermo, the thing recorded header temps of 930 degrees on the surface and 200 degrees radiant heat uncoated.
Coated inside and out radiant heat dropped to 80 degrees. That's pretty amazing.
Charles is offline
post #7 of 14 (permalink) Old 08-09-2007, 07:00 AM
Dark Side!
Send a message via AIM to redrocket Send a message via Yahoo to redrocket
Re: Ceramic coating
coat most of your exhaust--the exhaust housing on the turbo, up-pipes, exhaust manifolds, etc, it is well worth it, I think
redrocket is offline
post #8 of 14 (permalink) Old 08-10-2007, 03:08 PM
OEM Moderator
Tom S's Avatar
Re: Ceramic coating
Tom S is offline
post #9 of 14 (permalink) Old 08-10-2007, 03:19 PM
Limp Member
Kanman's Avatar
Re: Ceramic coating
Just have your hands ceramic coated. Problem solved.
I always point a shop fan directly under the hood when I need to work on my truck. Helps to cool under hood very quickly.
Any wraps out there that work well? I was kinda thinking of doing my down pipe.
01 F350 CC DRW 4x4 #46
Kanman is offline
post #10 of 14 (permalink) Old 08-13-2007, 10:15 PM
Dark Side!
Re: Ceramic coating
Cool It makes some good stuff, you could wrap your intercooler pipes while your at it
