Pyro flutters? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-26-2008, 06:14 AM Thread Starter
Know nothin' PSD driver
Greg373's Avatar
Pyro flutters?
My pyro started fluttering around 900' and would shoot up to 1300'. Any ideas?
[SIGPIC] 2001 F-350 CC SRW 4X4 Lariat;
PMR's
[/CENTER][/SIGPIC]
Greg373 is offline
post #2 of 9 (permalink) Old 02-26-2008, 06:26 AM
SUPERDF350's Avatar
Re: Pyro flutters?
Thermalcouple shoot.
2003 F-350 CCLB 4x4 6 spd man 5.5 Fabtech, 4"turbo stright piped,DP Tuner, hi-idle,40,60,80,100,120, ATS housing wicked wheel, tymar intake,firestone airbags.
SUPERDF350 is offline
post #3 of 9 (permalink) Old 02-26-2008, 06:36 AM
Re: Pyro flutters?
could just be bad gauge, resistance is what they work off of iirc. or it could be the probe it's self.
SuperStroker10 is offline
post #4 of 9 (permalink) Old 02-26-2008, 11:32 AM
Haul_n_horses2's Avatar
Re: Pyro flutters?
I think it is the dreaded pyro surge. Buy a TN as I hear they can't surge. J/K!
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #5 of 9 (permalink) Old 02-26-2008, 01:33 PM
Sleep well my brothers
yamt03's Avatar
Re: Pyro flutters?
mine did something like that and Joe(CSIPSD) AKA the gauge whore said to check the ground.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #6 of 9 (permalink) Old 02-26-2008, 02:41 PM
Banned
Re: Pyro flutters?
Mine did it a couple times. It was the gauge.
Mine was autometer. On the Isspros with that crazy box who knows.
Charles is offline
post #7 of 9 (permalink) Old 02-26-2008, 03:17 PM
Re: Pyro flutters?
That crazy box on the Isspro is just the same stuff that Autometer stuffs into the gauge itself. I've had WAY better luck with Isspro's than Autometer. Isspro are factory in almost all of our work trucks.
69W900A is offline
post #8 of 9 (permalink) Old 02-26-2008, 03:20 PM
you want some of this?
smorris's Avatar
Re: Pyro flutters?
My autometer is doing that now too. Works fine most of the time, then it'll peg out, and bounce around. Stupid gauge. As much as they cost, it should last longer. Bad part is I dont want to switch brands, cause I dont want to replace all the gauges to match.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #9 of 9 (permalink) Old 02-26-2008, 09:21 PM
Michael's Avatar
Re: Pyro flutters?
Yeah, it is usually a bad ground causing it. Unfortunately that bad ground may be through a bad connection inside the gauge!
Regards,
Michael Pliska
95 F350 CC DRW, ISSPRO Performax gauges, Diamond Eye 3x4" DP & 5" exh, MBRP tip, Baby Swamps & tunes, Trans VB mods, Dunrite TC, Lock-Right, Cal-Tracs
99 Silverado race truck
96 F250 RCLB, bone stock
00 Jetta TDI, Kerma Tunes, Der Chimera Stg 3 clutch
73 & 74 Vega race cars, 92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 Trans-Am 455
Michael is offline
