Early 99 intake plenums - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-25-2008, 09:52 PM Thread Starter
Construction Babysitter
wooner's Avatar
While I have the heads off, I am thinking about replacing the early 99 intake plenums with later model 3" ones. At this time, I don't want to replace the spider or any other plumbing. Question is this: Do the inlets fall in the same location on both, so that all I would have to find is a 2 3/8" to 3" reducing boot to connect the early 99 intake spider to the 99.5 intake manifolds, or is there more to it than that? Also, will the early 99 turbo clear the 99.5 intake plenums? I have heard that OBS guys had to do some BFH massaging of the intake plenum at the turbo to get it to clear.
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #2 of 9 (permalink) Old 02-25-2008, 10:16 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Early 99 intake plenums
I dont know about the clearance issues... But the location is the same. Airflo is just down the street from your jobsite, should be able to help you out!
Joe
CSIPSD is offline
post #3 of 9 (permalink) Old 02-25-2008, 10:18 PM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
hey i sorta did what your talking about only i did it backwards lol I have a late spyder with early plentums... I got the reducers from some silicone website and they work great and everything lines up
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #4 of 9 (permalink) Old 02-25-2008, 10:28 PM Thread Starter
wooner's Avatar
Ya, but the truck is up by the airport and the motor is on an engine stand right along side it.
Dave
wooner is offline
post #5 of 9 (permalink) Old 02-25-2008, 10:28 PM
Going Crazy
well walk its not that far lol
-Richard-
post #6 of 9 (permalink) Old 02-26-2008, 02:36 PM
Crusty old Bastich
3-StarJ.R.'s Avatar
Wooner, the stock number t-2383 boot is a true 2 3/8" to 3" , works perfectly.
turbohoses.com
The 3" SD intake doesn't have to have any "tweaking" to get it to clear the turbo....
Jim
96 CC 2wd Dually
BDP engine build
BDP D-66
BDP/Casserly Hybrids
BDP twin pump fuel system
Hypermax Rods
Caltracs
Detroit locker
FactoryTech tranny
3-StarJ.R. is offline
post #7 of 9 (permalink) Old 02-26-2008, 05:08 PM Thread Starter
wooner's Avatar
turbohoses.com
And that is the case with the 3" intakes with the early 99 turbo (Bean's D66)?
Dave
wooner is offline
post #8 of 9 (permalink) Old 02-26-2008, 05:43 PM
Going Crazy
They will probably clear... the early 99 pedistle is way higher than the OBS ones so i would think it should clear pretty easily.. im not 100&#37; but even if it did take a little massaging to get it in there it wouldnt be much
-Richard-
post #9 of 9 (permalink) Old 02-26-2008, 07:27 PM
Terminator Nation
It took only a little flattening on a rear corner on my 97. Not a big deal. And as I recall, it was more to clear the fuel line fitting thats not there anymore.
old man dave is offline
