Intake Tube - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 68 (permalink) Old 02-25-2008, 09:36 PM Thread Starter
Dieselgeek's Avatar
Intake Tube
Just installed my TN BB turbo, and would like to clean up the intake a bit. I'm running a stage 2 AFE, a ccv delete pipe, and the intake tube for the turbonetics. Does anybody have a metal tube that would work from the afe to the turbo? Dennis sells one for the H2E, but it won't work for drop-in turbo's. Kainers suggested an intake pipe from a cummins, and I looked at that option, but would like to get an intercooler type pipe with the appropriate rubber...
Thanks,
Nate
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
post #2 of 68 (permalink) Old 02-25-2008, 09:43 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: Intake Tube
You want to run one pipe from the AFE to the turbo instead of two with a peice of 4" pipe between them ?
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #3 of 68 (permalink) Old 02-25-2008, 09:49 PM Thread Starter
Dieselgeek's Avatar
Re: Intake Tube
Correct, I would like to run this set-up, but one that fits a drop-in turbo...
http://www.itpdiesel.com/store.php?c...on=show_detail
post #4 of 68 (permalink) Old 02-25-2008, 10:19 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Intake Tube
I've been wanting to do the same thing for a while now... Might have to put some parts together to do it! Would not be hard to moddify the ITP one to work on a drop in... two cuts and weld it up... but it would not look near as pretty as it does now.
Joe
CSIPSD is offline
post #5 of 68 (permalink) Old 02-25-2008, 10:21 PM
Sponsor
airflo71's Avatar
Re: Intake Tube
I don't know, maybe Air Flow can help?
airflo71 is offline
post #6 of 68 (permalink) Old 02-25-2008, 10:22 PM
CSIPSD's Avatar
Re: Intake Tube
Hey... I'll be the prototype rig... I can come down tonight!
Joe
CSIPSD is offline
post #7 of 68 (permalink) Old 02-25-2008, 10:26 PM Thread Starter
Dieselgeek's Avatar
Re: Intake Tube
I was thinking you could take a 4" intercooler pipe and bend it correctly, add rubber, and be done... I could be way off though...
Looked at my set-up today, and there isn't a great deal of bend involved. I'm not sure if you could use a mandrel bender or not. I've thought about mocking something up, and having a muffler shop bend the pipe...
post #8 of 68 (permalink) Old 02-25-2008, 10:28 PM
Sponsor
airflo71's Avatar
Re: Intake Tube
Come by our shop we are open 8am-5pm. We will prototype an intake kit.
airflo71 is offline
post #9 of 68 (permalink) Old 02-25-2008, 10:28 PM
CSIPSD's Avatar
Re: Intake Tube
All the local muffler shops will not be able to bend anything bigger then 3.5" and I doubt any of them have a mandrel bender... There is a place in Bend Or that had a mandrel to 5"...
Joe
CSIPSD is offline
post #10 of 68 (permalink) Old 02-25-2008, 10:29 PM
CSIPSD's Avatar
Re: Intake Tube
I'll come by tomarrow! if I left right now I doubt I would make it...
Joe
CSIPSD is offline
