38r and ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-25-2008, 04:57 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
38r and ???
Well let me have your oppinions on a good street/strip compound setup. I was thinking 38r and 4294 but that seems to be a little close in size. So that would leave a 45 or 47. What would seem to be beter?
I know a lot depends on fuel and I was thinking 275cc stoked A's with a large nozzle but I may just go with B codes. That part is some what undecided.
I would even look into a tn setup but I cant find any info or compressor maps.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 11 (permalink) Old 02-25-2008, 05:02 PM
Banned
Send a message via Yahoo to blk99
Re: 38r and ???
get ready for some wars over this one!
I have heard a 38R and a 47R make a GOOD setup...
blk99 is offline
post #3 of 11 (permalink) Old 02-25-2008, 05:05 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: 38r and ???
Dont mean to start any wars just want to make a decision once an be done. Its a lot of money to be throwing around and dont want to waste it on a junk setup. So if we can keep it civilized I would appreciate it.
Tow Mule
post #4 of 11 (permalink) Old 02-25-2008, 06:06 PM
Village Idiot
southmike's Avatar
Re: 38r and ???
have a look at charles set up...
makes me wish he could weld up an extra set
of plumbing pipes, and a shoe horn.
I believe it is a gt38r and a non "r" 47something
southmike is offline
post #5 of 11 (permalink) Old 02-25-2008, 06:27 PM
Re: 38r and ???
If your going with injectors that big you will need a bigger turbo than a 38r.
speediseverything is offline
post #6 of 11 (permalink) Old 02-25-2008, 06:33 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: 38r and ???
For a compund setup with the 38r being the 2nd stage? and a 45 or 47 as the first stage feeding it.
Tow Mule
post #7 of 11 (permalink) Old 02-25-2008, 06:33 PM
Back to Civilian Life!!
MILFORD's Avatar
Re: 38r and ???
how would he need something bigger then the 38R if he is using that as the small turbo in a compound setup which means what 10psi out of it.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #8 of 11 (permalink) Old 02-25-2008, 07:06 PM
Re: 38r and ???
I read to fast Missed the compund part, sorry.
post #9 of 11 (permalink) Old 02-25-2008, 07:09 PM
Village Idiot
southmike's Avatar
Re: 38r and ???
From my interpretation of charles post on this is :
basically with compounds your after something that spools fast , and provides a lot of air
anything bigger then something like a gt38r, reg h2e or even your stock turbo and you loose the quick spool,
anything smaller then a 47 and you loose the big umph your looking for.
well at least that is what my brain translated his post as.
now charles adds a lot more info on first and second stages, which I always get backwards, and much better and clearer, info on map layouts , and drive pressures...to explain why everything works .
another working twin setup is joey's, but really I don't know nothin' bout his
I know bwd sells a kit too.
post #10 of 11 (permalink) Old 02-25-2008, 07:24 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: 38r and ???
Exactly. The 38r will spool quick but i need someone to explain what makes the 47 beter than the 45 or vise versa. Also what housings or version of the 47(08 or 18).
From what I see the 47's have a much broader map which would make it a good all around turbo...I think
Tow Mule
