Intercooler questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 02-25-2008, 04:20 PM Thread Starter
<- Sums it up
strokin_early_99's Avatar
I am currently running the stock early intercooler. Will I pick up any power or better my ET with the addition of an aftermarket intercooler.
EGT's are not my issue here. I top out at 1500* at the end of the drag strip and my tow tunes will not go over 1200* when towing in the mountains. I am looking for more power without having my injectors opened up.
Thanks
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #2 of 12 (permalink) Old 02-25-2008, 04:27 PM
<----Colin Banks
mattymx's Avatar
Re: Intercooler questions
You wont really get any more HP, but you will be able to use more HP with lower EGT's with a better IC. I run a stock 6.0 on my EX and it helped a little bit to lower EGT's.
mattymx is offline
post #3 of 12 (permalink) Old 02-25-2008, 04:29 PM
Sponsor
airflo71's Avatar
Thanks
Do you have an aftermarket turbo? This will facilitate the need of a larger intercooler if the turbo is larger than stock. One, it will sustain cooler ,denser intake charge for longer periods of time, and 2 it will pull more heat out of the intake lowering your EGT's. A good rule is: whatever temperature you can take out of the intake charge, that amount will come out of the exhaust as well.
airflo71 is offline
post #4 of 12 (permalink) Old 02-25-2008, 04:36 PM
Banned
Send a message via Yahoo to blk99
he has a modded H2E with small B-codes...
blk99 is offline
post #5 of 12 (permalink) Old 02-25-2008, 04:43 PM
Sponsor
airflo71's Avatar
If you have an H2E that is modded with a wheel larger than the stock 61.5 it may be beneficial to get a larger intercooler with more surface area, you are putting more air into the system, at least help the intake charge by keeping as dense as possible.
airflo71 is offline
post #6 of 12 (permalink) Old 02-25-2008, 04:49 PM
Banned
I think his turbo is a 66mm/17cm exhaust....or it could be a 66/19cm.... not sure....
sorry howard...dont mean to answer questions for you....just keepin info goin...
blk99 is offline
post #7 of 12 (permalink) Old 02-25-2008, 04:54 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
He'll need a more efficient intercooler not necessarily a larger one with more surface area.
All things being equal a more efficient IC will give better numbers across the board due to a denser air charge.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #8 of 12 (permalink) Old 02-25-2008, 05:33 PM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
pretty sure your right with the 66/17
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #9 of 12 (permalink) Old 02-25-2008, 05:44 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I would not expect any huge gains... In the 10-20hp range... But cooler EGT's and better pressure ratios across the cooler...
With the 6.0 IC I am running now, at 40 psi post IC I am at 45 psi pre IC... I would bet those numbers would even out with a bigger IC (or Better... Read Sperco...)
Joe
CSIPSD is offline
post #10 of 12 (permalink) Old 02-25-2008, 06:02 PM
Village Idiot
southmike's Avatar
we could trade bumpers...I have a nice vintage early 99,
lighten your truck a lil that would help some
not sure if you would need anything special to use a h2e with a different intercooler, seems like one time when i wanted to order an h2e they wanted to know what type of IC i had..I was kinda thinking about adding a 6.0 just be cause it is cheap, and i am broke....but you do pulling comps, so you might have to step up to a real IC, like a spearco , or Di etc...
southmike is offline
