Couple Turbo install question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 02-25-2008, 01:52 PM Thread Starter
matthewd11's Avatar
H2E install:
Did you guys find it easier to install the up pipes with the pedastal on them already? Or install the up pipes separate from the pedastal? Will it even fit in there with them bolted together? This is with the trans in. As for the drain line, does it just sit in that hole of the pedastal drain? Just put some sealer around it i assume?
CCV Mod:
Are all of you guys running a catch can or can i just put a dump tube running from the dog house?
Thanks for the help in advance
matthewd11 is offline
post #2 of 12 (permalink) Old 02-25-2008, 02:07 PM
<- Sums it up
strokin_early_99's Avatar
Re: Couple Turbo install question
I put on the pepestal then put in the up pipes from underneath. The return line hole should have a machined groove that has an O ring in it that seals the drain pipe when installed. I also used a little Super gray permatex.
I run two catch cans in line then back into the intake. I used the hole that filter minder was in. I enlarged it and used a 3/4" barbed fitting that has the barbs machined off. And used a PCV valve O ring to seal it to the intake.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #3 of 12 (permalink) Old 02-25-2008, 02:12 PM Thread Starter
matthewd11's Avatar
As far as that O ring goes, i dont remember seeing one in the return hole on the pedastal, nor a machined grove. Do you know what size O ring it is off hand? Also where did you pick up those catch cans? Would it make a real mess if i just vented to atmosphere with no catch can?
post #4 of 12 (permalink) Old 02-25-2008, 02:38 PM
racehauler's Avatar
No it will be just fine. I have mine running from the valvecover straight down. About 4 feet of hose total and I don't get any mess.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 12 (permalink) Old 02-25-2008, 02:40 PM Thread Starter
matthewd11's Avatar
Is the dog house fitting for 5/8 or 3/4 hose?
post #6 of 12 (permalink) Old 02-25-2008, 02:49 PM
Firehunter's Avatar
I always wondered why all the enginnering of a catch can setup was needed...my CTD just had a hose hanging down the side of the engine and caused no grief?
2000 F350 PSD, 4X4, CC, LB, 6-speed/ PHP Tuning /1.0 Turbo (no wastegate) with WW/ 4" turbo back exhaust/ AIS Intake with fender sleeve/ Isspro EV gauges/
Just because you can, doesn't mean you should!
Firehunter is offline
post #7 of 12 (permalink) Old 02-25-2008, 05:45 PM
<-- GO BRONCOS
dblamp's Avatar
Its 3/4 inch, and just run it under the truck w/o a catch can. Mine ends right by the fuel tank. No problems.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #8 of 12 (permalink) Old 02-25-2008, 06:09 PM
Village Idiot
southmike's Avatar
hey howard did you get the fancy afe to h2e pip?
and as far as the ccv mod, i once read , or thought i read that you have to be carefull about where you run the hose , the size and such,
as it could lead to higher crank case pressures,
is there any meat to this or am I just a meat head.
southmike is offline
post #9 of 12 (permalink) Old 02-25-2008, 07:21 PM
<- Sums it up
I got the intake pipe from Dennis at ITP. I tried making one with parts I had and it only pissed me off when I was done because it looked like crap.
I don't like the smell of the CCV or the smoke coming from under the truck like a draft tube. I only like smoke coming from tires and exhaust..........
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #10 of 12 (permalink) Old 02-25-2008, 07:22 PM Thread Starter
matthewd11's Avatar
Its 3/4 I/D not O/D right? I got 3/4 ID
