TN BB Installed... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 02-24-2008, 06:19 AM Thread Starter
Dieselgeek's Avatar
TN BB Installed...
Finally decided it was time to install the TN today. Took far longer than I had planned, but such is life. Spent a great deal of time on the exhaust/up-pipe clamp. Part of the flange decided to weld itself to the clamp, and I had to break the clamp off to get it off. Took part of the up-pipe flange with it, but finally freed itself. After a trip to Ford for a new clamp, I was ready to roll. Looking back now, I forgot to put the o-ring from the stock turbo compressor into the TN, so tomorrow I'll go back and put it in, and check for any boost leaks. Turbo is rather laggy under 2k (6 speed), but spools up nicely once lit. Seeing around 25 psi right now, so I know I have a leak or 2. Deleted the EBPV, and added a non-ebpv pedestal while I was at it. Up-pipes had no leaks, so I left them for a rainy day. Plan on Regulated Fuel next, so I'll probably pull the turbo again, and will probably do uppies then. Also added Dieselsite boots, and need to re-adjust the intercooler boots to get them farther on, didn't know if they were suppose to go on ridged part of the intercooler or not, so they are a bit kinked right now, so tomorrow I'll re-adjust...
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
post #2 of 36 (permalink) Old 02-24-2008, 06:24 AM
Re: TN BB Installed...
keep us posted with your progress. the hardest part when i did my swap was the collector clamp...its a pita to get it lined up right and the clamp on
PMRCM#1
slowleak is offline
post #3 of 36 (permalink) Old 02-24-2008, 06:30 AM
Starting Over
kainers's Avatar
My 1st DIY turbo install took me 12 hrs.Partly cause that darn clamp at the collector.
kainers is offline
post #4 of 36 (permalink) Old 02-24-2008, 06:32 AM
Cummins Power
mech2161's Avatar
Part of your lag problem.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #5 of 36 (permalink) Old 02-24-2008, 06:38 AM
Layson's Avatar
I lost one of the T bolts for the clamp.... Spent several hours trying to find the stupid thing... that was fun!!
Layson is offline
post #6 of 36 (permalink) Old 02-24-2008, 06:40 AM
I had the same problem when i did my garrett. I could hear it leaking when i got on it. Got back to the house, aligned everything and havent had a problem since.
Diezel Dawg is offline
post #7 of 36 (permalink) Old 02-24-2008, 07:13 AM
Leave the mounting bolts very loose, install the clamp and then tighten everything. Makes it as easy as that clamp is gonna get. SD's are nice looking trucks, just wish they didn't stuff the engine in the glove box.
69W900A is offline
post #8 of 36 (permalink) Old 02-24-2008, 07:15 AM
the 7.3 isnt nearly as stuffed as the 6.0 or the 6.4
post #9 of 36 (permalink) Old 02-24-2008, 02:46 PM
PMRCM#1
slowleak is offline
post #10 of 36 (permalink) Old 02-24-2008, 03:09 PM
Proud PSN Sponsor
Deputydog's Avatar
Its probably easier to change the turbo out thru the glove box.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
