HPOP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 60 (permalink) Old 02-24-2008, 04:58 AM Thread Starter
HPOP
Hey guys I did the test on my HPOP tonight well I think I did ok not sure tho.I did the test that swampsdiesel.com has I used my scanner in KPA a good HPOP will run 19,310 which = 2800psi I drove the truck from 60-90 got high as 19,000 kpa then leveled out at 13,000 KPA which is 1885 psi so 1900psi is ok I guess for a early 99which has a 15deg pump.Do you guys think I should do a 17deg pump in my truck or wait till the pulse pump comes out and get that im gonna run stage 3s mini me hybrid injectors I want them to perform as best as they can.I dont get any ICP codes in a high tune which you normally would get with a chip the only code I get is a p1249 which is a wastgate code cause I have mine blocked off so what do you all think I should do here.
6.0 P/S Lariat FX4 CC/SB
37/12.50/20 nitto trail grappler 20'' black badlands
6inch lift
Mbrp Turbo Back Exhaust Cat Delete, Muffler Delete, 6Inch Tip,SCT Tuned By Eric,AFE Stage 2
Arp studs
Egr Junk deleted
Water Trans Egt Boost Fuel Phantom 2
Airdog 150, dozer diesel stage 2 RR, Fuel sump
stroker_1999 is offline
post #2 of 60 (permalink) Old 02-24-2008, 05:04 AM
HP Junky
Re: HPOP
So just order the Terminator pumps Mission accomplished
RockinJW is offline
post #3 of 60 (permalink) Old 02-24-2008, 05:22 AM
Limp Member
Kanman's Avatar
Re: HPOP
You might consider pulling your IPR and rebuilding it. I was getting crappy numbers like yours a while back. Spent $20 on an IPR rebuild kit and am back to 2500 numbers. Not great numbers, but a SOP difference. Also, you can build yourself a HPOP test gauge pretty easy. Pull a head plug install it there. I tape mine to the windshield and head down the road.
01 F350 CC DRW 4x4 #46
Kanman is offline
post #4 of 60 (permalink) Old 02-24-2008, 05:25 AM Thread Starter
Re: HPOP
I dont wanna spend 2grand lol where do you get the rebuild kit at
6inch lift
Arp studs
Egr Junk deleted
post #5 of 60 (permalink) Old 02-24-2008, 05:27 AM
Crazy Redneck
UNCOOL's Avatar
Re: HPOP
If a guy is going to run hybrids, why the hell do you guys tell everyone that they need ANY sort of HPOP? Hybrids will run great on a stock oil pump. Some are better than others.
Get your hybrids, have Tony reburn your chip (with a version of "ricekiller") and smile all the way to the bank.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #6 of 60 (permalink) Old 02-24-2008, 05:29 AM Thread Starter
Re: HPOP
Do you have hybrids and my truck will run good with the hybrids
6inch lift
Arp studs
Egr Junk deleted
post #7 of 60 (permalink) Old 02-24-2008, 05:30 AM Thread Starter
Re: HPOP
WIth the stock HPOP
6inch lift
Arp studs
Egr Junk deleted
post #8 of 60 (permalink) Old 02-24-2008, 05:42 AM
Crazy Redneck
UNCOOL's Avatar
Re: HPOP
WIth the stock HPOP
Yes to both.
I was running hybrids with a 15 degree pump. Hybrids grew a little, so I had to get oil.
Take a bit of the money you would have spent on oil and buy head studs. When you pull the injectors and send them off, put the studs in while you are waiting to get them back.
Marc
533/1050 5-8-10
#32
UNCOOL is offline
post #9 of 60 (permalink) Old 02-24-2008, 06:02 AM
Re: HPOP
Marc is right, hybrids are more of a gain to start with than oil is.
Go hybrids first, head studs, turbo, fuel system and the other supporting mods and it will run good.
Hybrids still need oil though, make that part of the package when you have the extra cash and you won't be disappointed
gregrob is offline
post #10 of 60 (permalink) Old 02-24-2008, 06:18 AM Thread Starter
Re: HPOP
Ur sayin I should do head studs to do i really need to i plan on doing a garrete gt38bb turbo and a regulated return with a fass system
6inch lift
Arp studs
Egr Junk deleted
