Tranny - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-24-2008, 01:20 AM Thread Starter
Tranny
Hey guys I was racing my buddy tonight and my over drive light started to flash then the SES light came on dont know what that was all about maybe you can give me a answer on that the tranny still shifts ok.
wes
6.0 P/S Lariat FX4 CC/SB
37/12.50/20 nitto trail grappler 20'' black badlands
6inch lift
Mbrp Turbo Back Exhaust Cat Delete, Muffler Delete, 6Inch Tip,SCT Tuned By Eric,AFE Stage 2
Arp studs
Egr Junk deleted
Water Trans Egt Boost Fuel Phantom 2
Airdog 150, dozer diesel stage 2 RR, Fuel sump
stroker_1999 is offline
post #2 of 11 (permalink) Old 02-24-2008, 04:02 AM
<-- GO BRONCOS
dblamp's Avatar
Re: Tranny
You need to pull the codes that were set by the lights. Then we can help you.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #3 of 11 (permalink) Old 02-24-2008, 04:52 AM Thread Starter
Re: Tranny
I got the code its a p1249 wastgate code lol cause I have the wastegate blocked off I think thats why it did that no tranny codes shifts ok so I think im ok
6inch lift
Arp studs
Egr Junk deleted
post #4 of 11 (permalink) Old 02-24-2008, 05:31 AM
Limp Member
Kanman's Avatar
Re: Tranny
Your stock trans is living on borrowed time, it wasn't made for the extra HP you are now pushing through it. Get ready its gonna blow one of these days if ya keep hammering on it.
01 F350 CC DRW 4x4 #46
Kanman is offline
post #5 of 11 (permalink) Old 02-25-2008, 02:47 PM
Village Idiot
southmike's Avatar
Re: Tranny
I wonder if the OD light was flashing because of TC slippage,
seems like sp diesels exhaust brake can cause the od light to flash on some trucks when the tc lock is engaged.
do you have a diy tc lock ?
yes that is purely just my wild guess, but a slightly educated guess.
the od light flashed for a reason, and it ain't no boost code.
if it did throw its own code it could have been a temporary code that disappeared.
also another thing you may want (besides a boost fooler)
is to look into a woods 6.4 TC kit, may be enough, with mini me's and a garret your at the high end of its limit i would think though,
they seems the perfect choice for pmr trucks.
BTW
who won?
southmike is offline
post #6 of 11 (permalink) Old 02-27-2008, 03:06 PM
panteramatt's Avatar
Re: Tranny
My wifes explorer did the same thing. Week later, no tranny.
panteramatt is offline
post #7 of 11 (permalink) Old 02-28-2008, 04:20 PM
Village Idiot
southmike's Avatar
Re: Tranny
ouch
post #8 of 11 (permalink) Old 03-01-2008, 06:00 AM
psychoSOCIAL!!
helvis's Avatar
Re: Tranny
yup from what i understand that OD light flashes when your demanding shifts out of the tranny and it cant do it, depending on the year the valve body has a shift solonoid that does this, my light would do that when i would hammer on it, but beware its gonna blow!!! mine did this for about a month then one day it wouldnt move anymore....now its totally suncoast and i cant believe the diff.. good luck.
02 7.3 psd, lots of useless mods.... (sold)
77 chevy c-10 2wd
87 fox body notch back 5.0
"The only difference between tattooed ppl and Untattooed ppl is, that tattooed ppl are way cooler....and can kick your ASS"
helvis is offline
post #9 of 11 (permalink) Old 03-02-2008, 02:14 PM
aklim's Avatar
Re: Tranny
Have you checked fluid condition and what the pan looks like?
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #10 of 11 (permalink) Old 03-02-2008, 02:48 PM Thread Starter
Re: Tranny
fluid smells like brand new tranny fluid ever since the od light was flashing which was like a weeks ago my tranny has been fine I dunno why it did that but the tranny fluid smells fine
6inch lift
Arp studs
Egr Junk deleted
