Waist line - Which girdle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 02-23-2008, 10:20 PM Thread Starter
Grumpy Old Bitter Bastard
389SixPack's Avatar
Question Waist line - Which girdle
So is Victoria Secret involved with one of these girdle designs? Has anyone seen the WOP and WOE girdles side by side? What do you actually get for the extra $1600?
WOP Girdle and Main Stud Kit will give the bottom end of your PSD the strength it needs to handle big HP. - $1089
Wipe Out - Girdle:
Our girdles are designed to tie the main caps into the pan rails to achieve optimum strength. We use 7075 aircraft aluminum and studs using H-11 steel. Includes: studs, bolts, and remote mount oil filter. - $2700
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #2 of 16 (permalink) Old 02-23-2008, 10:51 PM
cota's Avatar
Re: Waist line - Which girdle
Doesn't Black Widow have one that ties the mains to the pan rails?
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #3 of 16 (permalink) Old 02-23-2008, 11:38 PM
Savings?? what?
fordnut74's Avatar
Good timing of the thread. I need to climb out from under my rock a bit more. I was only aware of the WOP girdle. I was wondering if anyone had a girdle that tied to the pan rails. Now decisions decisions. Better girdle and OEM forged rods, or cheaper girdle and better rods.......
Late 1999 F-250 CC, 4x4, SB. 05 nose, Diff, suspension and badges,dynomatted. Revtek2.5 inch lift, Detroit true-trac Red-head steering, AATCO Trans, PI TC, Crowers, Girdle and Fire-Rings, ARP Studs, Blueprinted, DI Camshaft and intercooler, Cut Mahle LC pistons, Swamps Gen3& hybrids, Tubos??, MBRP 4",DP tuner, VEGISTROKE, More $$tuff
fordnut74 is offline
post #4 of 16 (permalink) Old 02-23-2008, 11:44 PM
Savings?? what?
fordnut74's Avatar
Who is WOE? Can't seem to find them
post #5 of 16 (permalink) Old 02-24-2008, 12:09 AM
Plays with Motors
Machinist's Avatar
There was just a thread on this a while back, just post into that one.
https://powerstrokenation.com/forums/...ghlight=girdle
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #6 of 16 (permalink) Old 02-24-2008, 02:19 AM Thread Starter
389SixPack's Avatar
http://www.wipeoutenterprises.com/
post #7 of 16 (permalink) Old 02-24-2008, 02:21 AM
cota's Avatar
Fordnut WOE is Wipe Out Enterprises. They have some one of a kind cool stuff but are spendy. I'm saving for a girdle and rods also.
2000,CC,4x4,auto
cota is offline
post #8 of 16 (permalink) Old 02-24-2008, 03:40 AM
HRT Performance
HotRodTractor's Avatar
I have seen both the WOP and WOE girdles side by side. I am running the WOP girdle in my truck, but WOE is very near me and I am running some of Dave's stuff. The WOE girdle is of the same construction that they use on the big cube pulling tractor motors. It ties the mains to the pan rail and requires a custom oil pan and pickup. The WOE is definately a nice but spendy peice. I'll look in the morning I think I have some close up shots of the WOE peice.
Jason
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #9 of 16 (permalink) Old 02-24-2008, 04:20 AM
Do you smell something?
Wackerjr's Avatar
Both do the same thing.....
The goal is to prevent main cap walk, and both do that very well.....
Neither will "add" strength to the bottom end.
Wackerjr is offline
post #10 of 16 (permalink) Old 02-24-2008, 04:22 AM
DarkShadowDiesel's Avatar
BWD's does not tie into the pan rails. it does utilize all four studs on each main cap though, whereas the WOP girdle only uses two of the studs. not sure if that matters or not, but fwiw. the WOP girdle really seems to be getting it done on many trucks. the wipe out girdle is serious!
2002 F250
DarkShadowDiesel is offline
