Source for injector o-rings? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-22-2008, 11:45 AM Thread Starter
Haul_n_horses2's Avatar
Need to get some replacement o-rings. What is the best source?
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #2 of 7 (permalink) Old 02-22-2008, 12:19 PM
All done now
Arisley's Avatar
Re: Source for injector o-rings?
International? That is probably who I would try first. Either there of a vendor.
Arisley is offline
post #3 of 7 (permalink) Old 02-22-2008, 01:45 PM
<- Sums it up
strokin_early_99's Avatar
powerstrokeshop.com has them. That is where I got mine when I needed them.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #4 of 7 (permalink) Old 02-22-2008, 02:25 PM Thread Starter
Do you have a part number. The number I have: XC3Z-9229-AB yields nada!
On edit: Apparently, it depends on how you enter the number in the trademotion database. Enter it in a part search and it comes up. Enter it by year, model etc. and it does not come up. Go figure.
post #5 of 7 (permalink) Old 02-22-2008, 02:27 PM Thread Starter
BTW, has anybody else had an increase in blue smoke on cold startup with ULSD transition? I have read the report from the State of Georgia, that they had injector seal/o-ring leakage when they switched from LSD to ULSD. Once the injector seals/o-rings were changed and experienced exclusively ULSD, there were no issues. I would have expected a lot more complaints about this from school bus fleets and 'strokers if it were that common.
post #6 of 7 (permalink) Old 02-19-2019, 05:02 PM
Powerpro7's Avatar
Thanks for the PN. I verified that it's the correct PN for my application so I went ahead and ordered it online. It should be arriving here in a couple of days. This is the oring https://www.fordpartsprime.com/oem/f...c3z9229ab.html
Powerpro7 is offline
post #7 of 7 (permalink) Old 02-20-2019, 05:26 AM
cadd's Avatar
Riff Raff Diesel
1999.5 F350 CC 4x4
& 2002 F250 CC 4x2 (Wifes)
cadd is offline
