31lbs stock turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 02-19-2008, 03:19 AM Thread Starter
31lbs stock turbo
is 31 lbs of boost dangerous for a stock turbo? it surges as soon as you barely touch the throttle on the interstate. i have a wicked wheel in the garage , on the truck ts 140, 5" exhaust, boost tube,and a tymar intake
jchapf250 is offline
post #2 of 35 (permalink) Old 02-19-2008, 03:21 AM
Re: 31lbs stock turbo
its probably not the healthiest of things for it
PMRCM#1
slowleak is offline
post #3 of 35 (permalink) Old 02-19-2008, 03:24 AM
Dangerous? Only when the thrust bearing fails and sends pieces of wheels fly'n.
25-28psi is about the top of the compressor map for that turbo, anything more than that and it really cuts down on their life.
69W900A is offline
post #4 of 35 (permalink) Old 02-19-2008, 03:25 AM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
probably wont last as long as it should
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #5 of 35 (permalink) Old 02-19-2008, 03:26 AM Thread Starter
well i should start by asking how can i reduce boost? truck has 150k miles and when it shifts to 2nd it barks 37" iroks
post #6 of 35 (permalink) Old 02-19-2008, 03:28 AM Thread Starter
is the boost tube a bad idea?
post #7 of 35 (permalink) Old 02-19-2008, 03:29 AM
Use the wastegate on the turbo to set the boost to whatever you want it to be. A better idea would be to upgrade to a better turbo.
69W900A is offline
post #8 of 35 (permalink) Old 02-19-2008, 03:31 AM Thread Starter
how do you set the boost?
post #9 of 35 (permalink) Old 02-19-2008, 03:31 AM
by adjusting the wastegate
PMRCM#1
slowleak is offline
post #10 of 35 (permalink) Old 02-19-2008, 03:34 AM Thread Starter
thanks guys
