FASS? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 02-18-2008, 03:11 PM Thread Starter
Sleep well my brothers
yamt03's Avatar
FASS?
I am tired of a fuel leak that I have and since I have been hearing more about upgrades I was wondering if I went with a FASS or Airdog and a RR could I get rid of this leakin ass fuel bowl?
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #2 of 33 (permalink) Old 02-18-2008, 03:14 PM
Banning Smut
PTSUPERD's Avatar
Re: FASS?
Yup. Probably would need some type of secondary in line filter after the pump for insurance though.
PTSUPERD is offline
post #3 of 33 (permalink) Old 02-18-2008, 03:17 PM
Village Idiot
southmike's Avatar
Re: FASS?
you could buy 2 orings and cure it probably...very common problem
but no a fass doesn't get rid of it..for the most part (see below).
only the itp fuel bowl delete does, and it doesn't replace it with anything...yet, although he recomends a filter be added.
now DI runs a fass and reg return and calls it good ...(which may mean they have a fuel bowl delete too)
if you run a reg return and a fass/ air dog you will have a much better fuel system anyway. Another option would be Dieselsites cpr fuel system, though you would prob have to ask bob , about ditching the oem filter.
southmike is offline
post #4 of 33 (permalink) Old 02-18-2008, 04:17 PM
DarkShadowDiesel's Avatar
Re: FASS?
fwiw the FASS has a 10mic post pump filter - you can also get lower rated filters to go in that spot.
2002 F250
DarkShadowDiesel is offline
post #5 of 33 (permalink) Old 02-18-2008, 04:22 PM
Re: FASS?
The high pressure FASS comes stock regualted around 55-60psi, so you don't need an additional regulator. Remove the fuel bowl, install y-block to feed the heads and your done. You don't HAVE to do a reg return just to do a fuel bowl delete while installing a FASS.
69W900A is offline
post #6 of 33 (permalink) Old 02-18-2008, 04:23 PM
Banning Smut
PTSUPERD's Avatar
Re: FASS?
ahh..I guess I was thinking the fuel was filtered past the tank but before it hit the pump.
PTSUPERD is offline
post #7 of 33 (permalink) Old 02-18-2008, 04:35 PM
Village Idiot
southmike's Avatar
Re: FASS?
as long as nothing smaller then 10 microns is between the
the filter outlet on the fass pump, anything that wears off the pump, if it is after the filter, (which it probably isn't) and your fuel injector then it is ok .
but that is a lot of pipe , hose , and a few connections from the middle of the truck , to the heads. Maybe some how purging the lines right before the last hook up would help some .
maybe i am just paranoid ...
post #8 of 33 (permalink) Old 02-18-2008, 07:05 PM Thread Starter
yamt03's Avatar
Re: FASS?
I have already done the o ring thing twice. I have also replace the drain valve and put 2 new o rings back in.
yamt03 is offline
post #9 of 33 (permalink) Old 02-18-2008, 07:11 PM
Re: FASS?
nope, after the pump mr. honeywell
you have a surprisingly diverse signature, sir.
not paranoid - just not familiar with the system
take a look at how it's set up when it's together, feed goes to water separator, up to pump, down from pump to filter, then out.
have you ever taken one apart? i just swapped pumps, so i can verify this for you. dennis @ ITP was also talking about this in another thread
the hose routing is not particularly overwhelming - you have the suction tube to the FASS (couple feet), then the return from the FASS to the filler neck (couple feet) and then the feed to the motor (i used 10'). it's pretty simple.
69W is right - you could even run a line from the FASS to the stock feed hardline after the pump, and then ditch the fuel bowl and just make some (3) feed connections - don't need the RR since the FASS is regulated.
2002 F250
post #10 of 33 (permalink) Old 02-18-2008, 09:17 PM
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
Re: FASS?
Getting rod of that POS was the best mod that I had ever done, no more leaks!
lildevil02 is offline
