What should I Add - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 02-18-2008, 02:19 AM Thread Starter
Construction Babysitter
wooner's Avatar
What should I Add
OK, engine is out, heads are off. I will be replacing head gaskets and putting on H11 studs. While the engine is out, I will be removing and reinstalling the oil pan to get rid of a pesky leak and replacing the early 99 intakes with 99.5 intakes. I will probably replace the glow plugs also. What else should I consider doing while the engine is out? This is going to completely strap me for cash, but I want to consider everything that would be worthwhile since the motor is out. Thanks guys.
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #2 of 18 (permalink) Old 02-18-2008, 02:22 AM
HP Junky
Re: What should I Add
Valve springs and pushrods?
RockinJW is offline
post #3 of 18 (permalink) Old 02-18-2008, 02:27 AM
If you had any water in a cylinder, replace that cylinders connecting rod. As Jacob said, throw some better valve springs in. I chose the Comp Beehive springs!
TerminatorEngineering is offline
post #4 of 18 (permalink) Old 02-18-2008, 02:27 AM
<<<<< Next Generation
boggerr's Avatar
ITP's fuel bowl delete
Waterpump
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
post #5 of 18 (permalink) Old 02-18-2008, 02:28 AM
<-- GO BRONCOS
dblamp's Avatar
Up pipes.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #6 of 18 (permalink) Old 02-18-2008, 02:29 AM
Drink til she's cute
Thuglike's Avatar
A 5.9?
Just kidding!!!! New up-pipes...headers?
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #7 of 18 (permalink) Old 02-18-2008, 02:49 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Did the HG blow, or did you just decide to pull it before you caused some problems?
Stock
PowerstrokeJunkie is offline
post #8 of 18 (permalink) Old 02-18-2008, 03:26 AM
Oooo, White Lightning !
Dieselboy's Avatar
Valve guides........Exhaust valves........Cometic HGs
A second turbo
And I second that 5.9
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #9 of 18 (permalink) Old 02-18-2008, 05:52 AM
Rear main seal. plus what everyone else said.
Oh, and up pipes if you dont' already have them.
Ported / coated exhaust manifolds.
gregrob is offline
post #10 of 18 (permalink) Old 02-18-2008, 06:06 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Everything suggested thus far, except the valves/springs, rod and piston, can be done at a later date with the engine in. Since we don't know your finances, all are throwing out ideas. Cometic head gaskets require you to deck the block and heads for specific flatness and finish specs. Stick with stock replacement gaskets. If you go with beehive springs, you'll need to machine seats - that can be done now or you can go with something like Comp 901 springs at a later date with no machining. Check your valves for wear, if burnt, guides, seats and new valves would be an idea. Consider the mods and consider your cash....
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
