reg. return question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 02-17-2008, 02:39 PM Thread Starter
What is the difference between a reg return system (ITP)and a crossconnect kit and HPX line from dino fuel alternatives performance wise? Is the difference in price worth it for someone who is not in upper RPMs alot?
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #2 of 40 (permalink) Old 02-17-2008, 02:52 PM
aklim's Avatar
Re: reg. return question
IF everything is perfect, they do the same thing. However, with the DFA kit, you will NOT be able to easily adjust your fuel pressure or know what it is without a gauge. The ITP kit will be a nice professional setup that will allow you to adjust your fuel pressure the way you want it to be adjusted. The best you can do with the DFA kit is to shim the flakey regulator and hope that is the pressure you want. IOW you can adjust it but no fine tuning. Also, I would get the HPX kit from ITP. Why? Because it is a hard line instead of a rubber hose. http://www.itpdiesel.com/store.php?c...on=show_detail
Would I get the HPX line myself? Probably not. Why? Because I knew I was destined for Big Oil. If you are not sure, get it and when you are done, sell it.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #3 of 40 (permalink) Old 02-18-2008, 04:33 AM
MAXIMUS OVERDRIVE
BDRUMMONDS's Avatar
Dig a little deeper, and send FN74(jason) at DFA an email about his full replacement fuel system. It is $699, and has all the hoses and fittings for a fuel bowl delete, the pressure is regulated by an orifice in the return line, has a guage test port, and comes with a FASS High Pressure Fuel Pump.
I have been running this kit for about 10K miles now and I love it. I am not sure if it is up on their site yet, but an email will be answered.
99.5 F250 4X4 CC SB isspros,DP, FASS pump, fuel bowl delete,SSHPX,OBA, 6.0 IC, 1.15 van turbo,ATS ported housing ,etc...
it goes and shows well for 320K
BDRUMMONDS is offline
post #4 of 40 (permalink) Old 02-18-2008, 05:09 AM
<==Drivin My Boat
EMD_16_645_E5's Avatar
I like my ITP kit, its prettier
1999.5 F-350 Standard Cab Long Bed 4x4
2000 VW Jetta TDI
Both a little worked over
For us New England Guys
EMD_16_645_E5 is offline
post #5 of 40 (permalink) Old 02-18-2008, 05:18 AM
Do you smell something?
Wackerjr's Avatar
Coming from a person who installs these kits daily........
Don't waste your time anywhere else, order it up from ITP and don't look back.
Wackerjr is offline
post #6 of 40 (permalink) Old 02-18-2008, 05:36 AM
Nice avatar, Jeremy.
TerminatorEngineering is offline
post #7 of 40 (permalink) Old 02-18-2008, 05:39 AM
How the hell can fuel pressure be regulated properly by an orifice in the return line?
That was a rhetorical question. Answer: IT CAN'T.
gregrob is offline
post #8 of 40 (permalink) Old 02-18-2008, 06:10 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
that was a rhetorical question. Answer: IT CAN'T.
Works just as good as cross drilled brake lines!
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #9 of 40 (permalink) Old 02-18-2008, 06:13 AM
hahahahaha
gregrob is offline
post #10 of 40 (permalink) Old 02-18-2008, 12:29 PM
MAXIMUS OVERDRIVE
BDRUMMONDS's Avatar
How the hell can fuel pressure be regulated properly by an orifice in the return line? ANSWER: It cant
tell me why it cant Greg.
