CCV Mod v.7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 02-17-2008, 04:26 AM Thread Starter
Subject Matter Expert
PowerstrokeJunkie's Avatar
CCV Mod v.7.3
I know there are several different takes on the CCV mod, but this weekend i took my exhaust-draft CCV off and did a little custom work.
Click the picture, tell me what ya think.
Stock
PowerstrokeJunkie is offline
post #2 of 26 (permalink) Old 02-17-2008, 05:08 AM
Custom Trailer Sales
TrailerHauler's Avatar
Re: CCV Mod v.7.3
Thats a nice clean setup!
I need to do it to, I'm probably not going to bother with a trap though. just run a road draft tube!
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #3 of 26 (permalink) Old 02-17-2008, 05:17 AM
Needs more hours per day
jtharvey's Avatar
Re: CCV Mod v.7.3
Kris, have you checked your crank case pressures with that setup? Wondering if the dual CCV helps...
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #4 of 26 (permalink) Old 02-17-2008, 02:13 PM
Re: CCV Mod v.7.3
What did you use to tap into the oil fill tube? I was advised to do this a couple of weeks ago. Very nice!
NWSUPRD is offline
post #5 of 26 (permalink) Old 02-17-2008, 02:21 PM
Re: CCV Mod v.7.3
the only thing i would have done different is put the vent that comes out of the oil trap at the top, and put the inlets below it.
PMRCM#1
slowleak is offline
post #6 of 26 (permalink) Old 02-17-2008, 02:30 PM
SeeYa's Avatar
Re: CCV Mod v.7.3
Looks good, Kris.
SeeYa is offline
post #7 of 26 (permalink) Old 02-17-2008, 03:39 PM Thread Starter
Re: CCV Mod v.7.3
No measurements on the CCV pressure, but if Ernest still has it at Smokin i'd take a run with the gauge hooked up...
I used a barb fitting with a 5/8" pipe thread, and a 3/4" nipple, or something close. I got the smallest pipe thread i could for the size of the nipple i wanted, and then holesawed it out, threaded it right into the neck.
Slowleak i have three different grades of steel wool in the canister, coarse, medium, fine at the bottom, and the heavy oil vapors that would cause a drip on the ground would be caught in the canister, sink to the bottom with the drain, and the lighter mist vapors just go right out. Before i started the truck, i disconnected the passenger side hose, and blew through it all the way to the tail pipes, amazingly enough it had very very little restriction, just felt like i was blowing through a 1" hose.
Stock
post #8 of 26 (permalink) Old 02-18-2008, 03:36 AM
jtharvey's Avatar
Re: CCV Mod v.7.3
If he's only got the one setup, I can tell you he doesn't have it right now...it's in my garage.
Jeremy
jtharvey is offline
post #9 of 26 (permalink) Old 02-18-2008, 03:52 AM
OEM Moderator
Tom S's Avatar
Re: CCV Mod v.7.3
One point to think about is there any possibility of freezing in extreme cold weather. I am not saying that it will just for you to consider it.
Tom
Tom S is offline
post #10 of 26 (permalink) Old 02-18-2008, 04:09 AM
MAXIMUS OVERDRIVE
BDRUMMONDS's Avatar
Re: CCV Mod v.7.3
Kris, as i said over there, it looks great.
For NWSUPRD you can tap the fill tube like Kris did, or you can buy a replacement cap and tap it (see Pics below) and for TRAILERHAULER here is a pic of mine that is "road draft" it is not near as pretty as Kris' and it does use plain old garden hose attachments, but it works.
99.5 F250 4X4 CC SB isspros,DP, FASS pump, fuel bowl delete,SSHPX,OBA, 6.0 IC, 1.15 van turbo,ATS ported housing ,etc...
it goes and shows well for 320K
BDRUMMONDS is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/14-7-3l-power-stroke-aftermarket-performance/6804-ccv-mod-v-7-3-a.html
Posted By For Type Date
7.3 Powerstroke CCV Mod_Yaelp Search This thread Refback 11-21-2015 04:51 PM
