triple stack ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 02-15-2008, 08:34 PM Thread Starter
triple stack ?
hey i have a edge EZ and a edge evolution can i stack anthor chip nwith them or is two the max?
big bad stroker is offline
post #2 of 21 (permalink) Old 02-15-2008, 08:39 PM
Oooo, White Lightning !
Dieselboy's Avatar
Re: triple stack ?
You can only max out the computer so much...........A DP tuner or TS chip seems to get the most with the 140 setting, stacking more is pointless...........Just ditch the edge and do yourself a favor and get a chip from the guys that do there own programs per truck.........I know
DP tuner
TS performance
DI does there own
Im sure there are others out there as well
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #3 of 21 (permalink) Old 02-15-2008, 08:44 PM Thread Starter
Re: triple stack ?
how do u like your ts chip?
post #4 of 21 (permalink) Old 02-15-2008, 09:08 PM
Village Idiot
southmike's Avatar
Re: triple stack ?
ts is a good chip, most chips are based on it.
custom tunners may find a lil bit of hidden power, or at least take advantage of what you have
and tune for it. tony wildman writes custom tunes for it, as does jody at dp tuner
david at di has his tunes etc..all need guages though.
chips tend to work better then stacking. Stacking is kinda ol school now,
most have gone to chips, because have more control and less heat issues then stacking. they also deal with improving tranny shifting etc...
southmike is offline
post #5 of 21 (permalink) Old 02-15-2008, 09:23 PM
Butt-Head
PHPDiesel's Avatar
Re: triple stack ?
Let's see:
1. You have a module that fools the PCM inputs and the PCM reacts accordingly.
2. You have a programmer that changes how the PCM reacts to the inputs.
The only other option you have is to install a chip onto the PCM. However, any changes in the programming that the Evoloution has done will be over-ridden by the chip. On the same token, the corrupt signals from the EZ module will totally screw up the tuning done by whoever burns the chip. So either keep your EZ/Evo and live with it OR get custom tuning.
Cody
PHPDiesel is offline
post #6 of 21 (permalink) Old 02-15-2008, 09:29 PM
Back to Civilian Life!!
MILFORD's Avatar
Re: triple stack ?
Keep in mind your stock injectors can only push out so much fuel which is the 120 and the 140 setting on a good chip.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #7 of 21 (permalink) Old 02-15-2008, 10:02 PM
Dieselboy's Avatar
Re: triple stack ?
Custom tuning is WAY better.........I only ran my TS for a few hours, It came along with my trans swap and was the wrong PCM......BUT the new PCM I bought came with a DP tuner 80 Econo setting flashed into it.......Compare to the Edge Evolution I borrowed was like night and day. the 80 Econo had more power than the Edge 100 extreme setting....
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #8 of 21 (permalink) Old 02-16-2008, 04:31 PM
Got 'Er Did
lownslow's Avatar
Re: triple stack ?
i got a dp 80hp pcm
gonna stack a edge juice w/ additude
i was told it would work
and not overide the pcm just act like a stack
and then i gots my gauges
2009 Mustang GT Premium 5spd
BBK Long Tube Headlers and Off Road X Pipe
waiting for the squeeze
1995 F350 Crew Long 4x4 Dually
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #9 of 21 (permalink) Old 02-16-2008, 04:40 PM
Sponsor
airflo71's Avatar
Re: triple stack ?
Why take a progrmmer that supposedely is inputing stategic fuel events to maximize cylinder pressure and confuse it? Adding more fuel and more air is the way to make power, how you make it is dependent on tuning. If you stack and stack you are going to get the most un-efficient, hollow feeling power and eventually break something expensive.
airflo71 is offline
post #10 of 21 (permalink) Old 02-16-2008, 04:45 PM
Re: triple stack ?
Pringles, are the only chips that are safe to stack. A wise man once said
To answer your question more in-depth. The term "stacking chips" comes from the dodge guys who can have boxes that do more than one thing. For example they could have a programmer that adds more fuel, but does not increase timing. Then they can add a timing module to achieve the desired result.
Our trucks only have about 2 safe ways to increase power, first and foremost is a chip or programmer. These completely override the stock computer program and makes the drivetrain operate according to the custom tuned chip / programmer.
The other mod that is popular with our trucks is an ICP mod. This is a resistor placed in the wiring harness to the ICP sensor. It reduces the value of the reading the ICP sensor gives the PCM and therefore the PCM compensates by asking for more pressure. More pressure to the injectors = more fuel = more power.
Only use this if you DONT' have a chip though, and expect minimal gains.
When you get a chip or programmer, the tuner has already increased the commanded ICP value and the ICP mod would just complicate things.
gregrob is offline
