Turbo surge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 02-15-2008, 08:09 PM Thread Starter
Turbo surge
I need some help. I am having surge problems and I have been told to do the ats housing. I think I have found one, but I am not sure if its the one that I need or do they differ.
mike01b is offline
post #2 of 24 (permalink) Old 02-15-2008, 08:41 PM
Oooo, White Lightning !
Dieselboy's Avatar
Re: Turbo surge
An ATS housing should be the same for all years of the stock superduty turbo.......Except the early 99 there might be a different one if you have an early 99
You could just do a compressor wheel upgrade.....Its cheaper (under 100$) and it might solve it, if not it will only help with the ATS
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #3 of 24 (permalink) Old 02-15-2008, 09:22 PM
Village Idiot
southmike's Avatar
Re: Turbo surge
early 99's don't surge....that is the one good thing about them.
they have a stock ww and it seems to work better then the ww added to the 99.5, prob something to do with the e99 housing .
I say that because not all of the 99.5 have success with just a ww.
southmike is offline
post #4 of 24 (permalink) Old 02-15-2008, 09:28 PM
Butt-Head
PHPDiesel's Avatar
Re: Turbo surge
The ATS is the only TRUE cure for surge on a stock turbo. Besides, it's a ton easier to put on than the wicked wheel and you don't have to worry about ruining a turbine blade or ending up with an exhaust leak.
Cody
PHPDiesel is offline
post #5 of 24 (permalink) Old 02-15-2008, 09:32 PM
bigd4me2's Avatar
Re: Turbo surge
if you have a 1999.5 or up and you get an ats, you will not be able to make your turbo surge. if your turbo is in good shape it's money well spent, unless you need more boost than 25 to 28 psi.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #6 of 24 (permalink) Old 02-15-2008, 09:38 PM
Butt-Head
PHPDiesel's Avatar
Re: Turbo surge
Oh please!! Nobody needs that much boost......
Oh, and do you ride? Just assuming due to your avatar.
Cody
post #7 of 24 (permalink) Old 02-16-2008, 06:14 AM
Re: Turbo surge
The wicked wheel is a waste of money. Either buy the ATS housing. This will cure ALL surging problems. Or purchase a new BB turbo. Dont waste you time or money on a wicked wheel.
2002 F350 DRW, 38r Turbo, Terminator T500, REG return fuel system, CTS Evo Custom tuned by Bill at Powerhungry Performance, bts converter, S&B intake, Snows Stage 3 Water/Meth. Mcculloch hids 6k.
toypuller is offline
post #8 of 24 (permalink) Old 02-16-2008, 06:58 AM
Re: Turbo surge
The eary 99's and OBS trucks are more resistant to a surge condition due to the compressor wheel design, it has very little to do with housings. The "WW" style compressor wheels move a bit less air than the later wheels do, which is why you don't get surge as easy. Another option, a better one IMO would be to put a bit bigger turbine housing on it to slow the shaft speed so you are not moving so much air at low RPM.
69W900A is offline
post #9 of 24 (permalink) Old 02-16-2008, 07:03 AM
Banned
Send a message via Yahoo to blk99
Re: Turbo surge
I beg to differ!!
I have heard Moose99ps's early 99 turbo surge like no ones business!!!! that thing is fukin bad!!!! especially with a load!!!
I have also gotten mine to go it a time or 2....usually only when it upshifts at WOT....
blk99 is offline
post #10 of 24 (permalink) Old 02-16-2008, 07:08 AM
Re: Turbo surge
EVERY turbo WILL surge. EVERY compressor map has a SURGE line on it. Some turbo's will not surge on a particular application due to engine setup, turbo sizing, etc.
OBS will surge, WW will surge, even an ATS housing is capable of it. A properly spec'd turbo is just designed to run below the surge line in a particular engine tuneup.
69W900A is offline
