Traction bars and Ladder Bars - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 72 (permalink) Old 02-15-2008, 03:42 AM Thread Starter
I have been searching the entire forum to find anything on how to build traction bars and ladder bars properly.
Properly built traction bars should not need a shackle to provide full range of suspension. What is the equation to calculate what length of bars provide the correct geometry? What torque and HP ratings are required? What diameter and wall thickness of tubing is necessary? (yes bigger diameter is better but $$ and heavy)
Properly built ladder bars should provide full range of suspension while having a shackle of proper length that allows rotation of the ladder at the same rate as the axle would rotate under normal suspension travel.
CALPOLY's motto is learn by doing. Currently I am looking for senior project ideas. I was asked by strokin_early_99 to build some traction bars for his truck which brought me here for info and designs. It seems everyone has ideas but no one knows what the equations are to solve for the correct length for every suspension configuration. If anyone is willing to sponsor a senior project to reaserch suspension geometry.
My goal would be to build a set of equations that can be used to determine proper dimensions for both traction bars and ladder bars, as well as determine the best uses of each design. This reaserch will then be followed up by the construction and testing of both systems. After completion of the project the suspension systems will be the sponsors to use and abuse. If you are interested and would like more info feel free to give me a call.
Nicolas Hellewell
Cal Poly Mechanical Engineering Senior
510-915-1187
Calpoly Racing is offline
post #2 of 72 (permalink) Old 02-15-2008, 06:15 AM
What else?
smokyred's Avatar
Re: Traction bars and Ladder Bars
Here's some info about my traction bar setup, to be honest, my traction bars were built to have the same angle as the rear half of my 2 piece driveshaft. I have an extended cab long bed (155" wheelbase) truck, and the bars came out to being ~6 1/2 feet long.
They work very well hauling loads of over 1k lbs. in the bed and they still allow full suspension droop when on a 2 post lift, while not giving any indication of binding. They also help the truck hold the road better when cornering.
For the bars themselves I used adjustable track bars from Ridewell suspensions because we had lots of them laying around, I cut them in half and welded in some 1 1/8" solid round stock. They give a little if you pull down on them with your weight, but they don't give when they're under compression.
I know all of that doesn't sound very scientific and all, but it sure works good.
If we had equations to help figure it out, that sure would help!
Dave
smokyred is offline
post #3 of 72 (permalink) Old 02-15-2008, 11:53 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
i did the same thing except w/ 1 1/4 pipe, and cut top links in half. seem to work great. and mine are 6 feet long they go to where the frame drops back down.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #4 of 72 (permalink) Old 02-15-2008, 03:04 PM
Banned
Get a 1/10 Scale RC truck and build the link suspension yourself from scratch, over and over in as many ways as you can think of. Parallel 4 link with panhard bar, triangulated 4 link, triangulated with the uppers, triangulated with the lowers, triangulated toward the axle, triangulated toward the center of the vehicle, so on and so forth until you have a good understanding of how dimensional changes effect the suspension operation.
Or model different link geometries in some form of CAD software.
Either one will do wonders for your understanding. I would give the tip of the hat to the physical modeling for conceptual understanding and the computer modeling for the physical understanding on a more precise basis, in terms of exact lengths, angles and such.
And you are absolutely right, properly designed link geometry does not require any form of shackle nor does it restrict the suspension cycle in any way other than the movement you are choosing to restrict with the link itself.
Charles is offline
post #5 of 72 (permalink) Old 02-15-2008, 07:53 PM
Electrical Nomad
Mayday's Avatar
search on google. but for the most info i would log on to Pirate4x4 and search. dont post up until you have search the site for at least a week it is full of info and people on there are tired of going back over it. i think you will find what you are looking for there. if you want no binding at all you need to have a shakle or slip joint. solid links on a leaf sprung suspension equals binding.
2000 F250- hybrids, GT38R, ATS trans, mod IDM, ITP fuel system, and DP tunes.
Mayday is offline
post #6 of 72 (permalink) Old 02-15-2008, 09:15 PM
I like my ladder bars. Not everyone does. They work very well though. I have plenty of travel.
Pics are here:
www.mcspadden.cc/ladderbars.html
NWSUPRD is offline
post #7 of 72 (permalink) Old 02-15-2008, 09:20 PM
Evil Genius
DCSpecial's Avatar
You measure the leaf spring, figure out it's range of motion during suspension movement and then calculate out what length to make the the bar so that the arc that the bar travels in matches the movement of the leaf springs.
DCSpecial is offline
post #8 of 72 (permalink) Old 02-15-2008, 10:28 PM
Electrical Nomad
Mayday's Avatar
Pics are here:
i like the looks of those. i might have to copy your design.
Mayday is offline
post #9 of 72 (permalink) Old 02-16-2008, 12:05 AM
Be my guest. I paid for them to be made for my truck that is not lifted in the rear. Only leveling out the front. I had a difficult time finding anything that would fit so had them made.
Copy away, it just feels good that I am not the only one that likes them.
I got them to stop sheel hop/axle wrap and did not realize the other handling enhancements like cornering. They really set you down in a hard turn.
Make for fun driving.
NWSUPRD is offline
post #10 of 72 (permalink) Old 02-16-2008, 12:39 AM
Banned
Please don't take this the wrong way, but that is simply incorrect. And it's explicitly the kind of link "design" that the OP does not want anything to do with.
A shackle or slip joint on an Anti-wrap link is an engineering abortion.
Charles is offline
