Dino Fuel Alternatives CCK & HPX Line Pics - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-15-2008, 01:21 AM Thread Starter
fords4life's Avatar
Here are the pics of my install last weekend.
Tee @ Fuel Return Line
CCK Connection @ Passenger's Side Head
HPX Line on Driver's Side
HPX Line on Passenger's Side
HPX Line on Driver's Side & CCK Routing
I added the blue wire loom for a little extra protection. The install really isn't all that bad.
1999.5 F-250 XLT Crew Cab Short Box
4X4 7.3L Powerstroke
fords4life is offline
post #2 of 6 (permalink) Old 02-15-2008, 01:24 AM
Firehunter's Avatar
Re: Dino Fuel Alternatives CCK & HPX Line Pics
I assume you took out the CAC tubes and the spider...anything else?
2000 F350 PSD, 4X4, CC, LB, 6-speed/ PHP Tuning /1.0 Turbo (no wastegate) with WW/ 4" turbo back exhaust/ AIS Intake with fender sleeve/ Isspro EV gauges/
Just because you can, doesn't mean you should!
Firehunter is offline
post #3 of 6 (permalink) Old 02-15-2008, 01:30 AM Thread Starter
fords4life's Avatar
Loosened up the alternator/PS pump bracket and bungeed it to the driver's side and forward to get to the Return line to cut and add the tee.
Removed the A/C compressor bolts and slid it towards the passenger's side to get to the passenger's side fuel port.
Removed the passenger side CAC @ the turbo and just pushed it back and up as far as possible to get to the passenger's side rear HPO port. Didn't remove it from the intercooler.
Removed the intake tube completely to access the driver's side rear fuel and oil ports.
post #4 of 6 (permalink) Old 02-15-2008, 04:43 AM
Be honest, did you notice any improvement? in any aspect.
2002 F350 DRW, 38r Turbo, Terminator T500, REG return fuel system, CTS Evo Custom tuned by Bill at Powerhungry Performance, bts converter, S&B intake, Snows Stage 3 Water/Meth. Mcculloch hids 6k.
toypuller is offline
post #5 of 6 (permalink) Old 02-15-2008, 01:13 PM Thread Starter
fords4life's Avatar
Read these threads....
https://powerstrokenation.com/forums/...ead.php?t=6508
https://powerstrokenation.com/forums/...753#post118753
post #6 of 6 (permalink) Old 02-15-2008, 11:01 PM
Firehunter's Avatar
Thanks for the info!
