Twin turbo setup ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 02-15-2008, 12:03 AM Thread Starter
charlie99's Avatar
Twin turbo setup ?
How are you guys with the twins mounting the turbo in the passenger battery location, what kind of pedistal is the best way to go so far, also where is the best place to get your oil supply from, and to drain the oil back to the motor.
Thanks guys
'95 PSD 3" RSK, 3" bodylift, 37x13.50x20 xterrains. Tymar intake,ARP studs, comp 910s, DIY 238 hybrids with 200% nozzles, 6.0 intercooler, 3.5" downpipe to dual 4" stacks, CCV mod, IDM mod, DP tuner mod stock, 40t, 80e, 140r, fass 150/180, ITP regulated return, TE big oil, GTP38r turbo, lookin for 500 ponies
charlie99 is offline
post #2 of 34 (permalink) Old 02-15-2008, 01:07 AM
Banned
Re: Twin turbo setup ?
I used 1/2" Carbon Steel for the mount and bolted it down to the existing mount on the accessory bracket where the AC compressor would normally go.
Fed it oil from the end of the Gen3 reservoir through a -4 Braided line, and drained it to a bung welded in the passenger's side of the oilpan through a -12 Braided line.
If you dig through my webshots you can get an idea of the space an 88mm charger takes up and use that to gauge how your charger will need to be placed, and what might need to be relocated or removed.
Video shows the final setup with both gates operational.
http://videos.powerstrokenation.com/...b6012cf346.htm
Good Luck, you'll likely need it.
Charles is offline
post #3 of 34 (permalink) Old 02-15-2008, 01:38 AM
I feed mine from the oil filter base and drain mine into the valve cover. My air filter is where the battery use to be.
http://videos.powerstrokenation.com/...2f017b538e.htm
TerminatorEngineering is offline
post #4 of 34 (permalink) Old 02-15-2008, 02:20 AM
fueled by Colecovision
golfer's Avatar
Garage
fed? or feed...
golfer is offline
post #5 of 34 (permalink) Old 02-15-2008, 02:21 AM
feed, fed, push, pull, walk, run, sink, or swim.
post #6 of 34 (permalink) Old 02-15-2008, 02:38 AM
Originally Posted by golfer View Post
fed? or feed...
Since it happens every time he drives it, and not just once, feed would be the proper tense.
You an english teacher, gopher?
gregrob is offline
post #7 of 34 (permalink) Old 02-15-2008, 02:55 AM
golfer's Avatar
Garage
can you use present tense when referencing something that is in the past?
For example:Joey could correctly say either of the following...
Before my truck tossed a rod, I used to feed the oil....
or:
Now that my truck is currently an Andersen edition it fed the oil from...
see how important tense is?
golfer is offline
post #8 of 34 (permalink) Old 02-15-2008, 02:58 AM
Laces Out
bigrpowr's Avatar
he did the twins AFTER it chucked a rod, i think its been up and running since august.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #9 of 34 (permalink) Old 02-15-2008, 02:58 AM
Sponsor
airflo71's Avatar
Charles, that better not be a K & N filter on your GT4718!!!
airflo71 is offline
post #10 of 34 (permalink) Old 02-15-2008, 03:00 AM
2Cruel
moremph's Avatar
My turbo is mounted off a bracket that two comes off where the ac compressor once resided. I feed my oil from a factory port, and i drain into a bung that i put into the pan
Travis
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
