opinions on the hpx and cck? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 02-14-2008, 09:28 PM Thread Starter
panteramatt's Avatar
Whats your guys opinions on these that have used them? Do they actually work and can you feel a difference in power with them?
panteramatt is offline
post #2 of 39 (permalink) Old 02-14-2008, 09:30 PM
Re: opinions on the hpx and cck?
They do what they're supposed to do, but there is no difference in power.
gregrob is offline
post #3 of 39 (permalink) Old 02-14-2008, 09:32 PM Thread Starter
So they only make the motor run smoother and more quiet?
post #4 of 39 (permalink) Old 02-14-2008, 09:35 PM
The crossover smooths out the idle a little.
The CCV simply keeps oil vapor from getting in the intercooler.
gregrob is offline
post #5 of 39 (permalink) Old 02-14-2008, 09:36 PM
fords4life's Avatar
Yes and no.... I would say that the performance issue depends on the vehicle. They definitely smooth out and quiet down the injectors. In my case, I picked up almost 6psi of boost with the stuff in my sig. The HPX line and CCK were the only two things I've done to the truck since I bought it, everything else was already done.
See the thread I made when I did my CCK Kit..... Mod Party....CCK & HPX Line
I wouldn't say that my results are typical, but I'm sure happy with these mods.
1999.5 F-250 XLT Crew Cab Short Box
4X4 7.3L Powerstroke
fords4life is offline
post #6 of 39 (permalink) Old 02-14-2008, 09:39 PM
fords4life's Avatar
He's talkin about the CCK, not CCV..... Fuel Cross Connect Kit from Dino Fuel Alternatives.
post #7 of 39 (permalink) Old 02-14-2008, 09:50 PM
Banned
Send a message via Yahoo to blk99
I LOVE my HPX!!! really helped smooth the idle!!!!!
blk99 is offline
post #8 of 39 (permalink) Old 02-14-2008, 10:15 PM
Your sig has a hypertech chip, that would be the reason for your increase boost. Not the oil or fuel crossover lines.
gregrob is offline
post #9 of 39 (permalink) Old 02-15-2008, 12:42 AM
fords4life's Avatar
Hypertech was in when I bought the truck. It was already trying to push the fuel and oil. The CCK and HPX allowed that fuel and oil to flow and also stopped the #8 cylinder from getting starved. I was failing the Cylinder Contrib Test on #8 before the I installed the two and Pass with flying colors now.
Performance gains with or without a chip are possible with the CCK and HPX. The question is what do you consider performance? Improved efficiency is a performance gain. While you may not gain horsepower or boost with the install, you will get improved throttle response, quiter injectors, and a smoother motor. I would definitely consider those performance gains. Without a chip, you may not see the increased boost, but you will get the above 3 things. Those were all I was expecting and even if I hadn't picked up the boost, I would still say this install was well worth it!
post #10 of 39 (permalink) Old 02-15-2008, 12:46 AM
I agree with that, I just dont agree that you picked up 6lbs of boost from these two mods.
gregrob is offline
