D66 Turbo Spool - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 02-14-2008, 02:52 PM Thread Starter
Construction Babysitter
wooner's Avatar
D66 Turbo Spool
Here are a couple of quick videos of my D66 in action. I think it spools pretty darn fast. How does this compare to those of you with BB turbos?
http://good-times.webshots.com/video...01425948JfiNPQ
http://good-times.webshots.com/video...01425948gFGTeI
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #2 of 18 (permalink) Old 02-14-2008, 03:15 PM
Laces Out
bigrpowr's Avatar
Re: D66 Turbo Spool
if you're already above the given rpm range that the turbo lights at, most any turbo is going to come on that fast or faster. the tell tale sign is what rpm were you at when you slammed the throttle. looked and sounded good to me.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #3 of 18 (permalink) Old 02-14-2008, 03:41 PM
Banned
Send a message via Yahoo to blk99
Re: D66 Turbo Spool
get a vid from a stop sign/light and see....cause you were already at like 5 pounds when you mashed it.....
but it looked and sounded good!!
blk99 is offline
post #4 of 18 (permalink) Old 02-14-2008, 03:44 PM Thread Starter
wooner's Avatar
Re: D66 Turbo Spool
That makes sense to me. I was taveling down the highway when I filmed it.
Here is another quick video I took a little while ago. As you can see, I just came around a corner from a stop and then gunned it.
http://good-times.webshots.com/video...01425948UlnMcl
Dave
wooner is offline
post #5 of 18 (permalink) Old 02-14-2008, 03:45 PM
JHill's Avatar
Re: D66 Turbo Spool
i cant comment as i havent ran a BB, looks pretty quick from the videos. I will be following this post for responses, hybrids going in next month. i planned a D66, but I am still uneasy with the stock center section and boost #'s that are possible with the added fuel. how hard have you beat on it? i know it hasn't been in long. with my 6speed it sees WOT or close several times a day when rowing through the gears, i assumme you have the wastegate adjusted to keep it under 40#. BTW good lookin ride, i passed you a week or so ago, you were headed South on I-205 just before the I-5 interchange
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #6 of 18 (permalink) Old 02-14-2008, 04:05 PM Thread Starter
wooner's Avatar
Re: D66 Turbo Spool
Well, I can't let you pass me . Anyway, I have my Turbomaster wastegate set to open exactly at 38 psi, and as you look at the video, it opens immediately at 38 psi. It is a nice piece compared to the stock or the Big Head (I have tried them all). As far as beating on it, I have made numerous WOT passes since I got the tuning back from Jody, but I rarely will see over 20 psi on a regular daily driving basis. I have notice a little boost pattern lately. During normal daily driving acceleration up to 1/2 throttle, boost will go to about 20# and no higher. During 3/4 throttle acceleration, it will go right to 34# and stop. During WOT, it goes right to 38#. Boost is purely a function of throttle position.
Dave
wooner is offline
post #7 of 18 (permalink) Old 02-14-2008, 04:47 PM
cota's Avatar
Re: D66 Turbo Spool
With B codes pushing it, it better spool quick till the day it dies.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #8 of 18 (permalink) Old 02-14-2008, 05:06 PM
<- Sums it up
strokin_early_99's Avatar
Re: D66 Turbo Spool
I will tell you that my old D66 would light from a dead stop in a flash. I love that turbo for just that right there and towing was great at low RPM because it would light do darn easy.
Your vids look better than the other spool up vids that have been posted on here......... That needle moves pretty darn quick, looks good....
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #9 of 18 (permalink) Old 02-15-2008, 12:23 AM
Wheelie Dude
bean's Avatar
Send a message via AIM to bean
Re: D66 Turbo Spool
Poor little D66's, some of them have taken such a beatin .
Smokin' Hot Hooker- 2002 F350 Dually 4x4 6spd- 5.9 CR-
BDP Drag Truck- 81 C10-5.9CR, BTS 4R, Goes Fast
Beans Diesel Performance
bean is offline
post #10 of 18 (permalink) Old 02-15-2008, 01:03 AM Thread Starter
wooner's Avatar
Re: D66 Turbo Spool
Bean, How may have blown up though?
Dave
wooner is offline
