Alcohol or acetone for cleaning PCM contacts? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-13-2008, 06:00 PM Thread Starter
Peon
jvencius's Avatar
jvencius is offline
post #2 of 7 (permalink) Old 02-13-2008, 06:05 PM
<-- GO BRONCOS
dblamp's Avatar
Re: Alcohol or acetone for cleaning PCM contacts?
I used nail polish remover and everything was fine.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #3 of 7 (permalink) Old 02-13-2008, 06:15 PM
depends. alcohol will evaprate completly. some nail polish removers have other things in it that might leave a residue. this is what radio shack told me about the subject.
kbud14 is offline
post #4 of 7 (permalink) Old 02-13-2008, 06:27 PM
<----Colin Banks
mattymx's Avatar
I use alcohol. Plus if you have an accident, alcohol is far more forgiving when it spills.
mattymx is offline
post #5 of 7 (permalink) Old 02-13-2008, 06:49 PM
<- Sums it up
strokin_early_99's Avatar
^^^^^ I totaly agree.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #6 of 7 (permalink) Old 02-13-2008, 08:56 PM
28 cent #2
daryl4412's Avatar
I used alcohol as well..worked fine just poured some in the cap form the bottle and went from there..have fun
daryl4412 is offline
post #7 of 7 (permalink) Old 02-13-2008, 11:58 PM
bigd4me2's Avatar
just don't scrub too hard whatever you do! i can't remember if the contacts are gold but, if you start to see the copper showing thru the edges, stop going across the connections. go length wise instead of across the conductors, or you may have to have the board retinned.not tryin to scare you, cause they need to be cleaned properly! just don't clean so far as to see the metal underneth the first layer too much!!! and ya, i used alcohol beause i used all my nail polish remover at hollowen, or that drag party i went to, oooooppss!!
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
