Where can I go to get rods installed? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-13-2008, 05:26 PM Thread Starter
sandnut's Avatar
I'm considering replacing my PMR's with forged rods from a 99/00 motor. It's a much bigger job than I want to tackle in my garage, so I'm wondering what places in the southwest US would do it, and what's a reasonable price to pay? I'm guessing it'll be in the $5-6,000 range, does that seem about right? I figure I'll include new rod & crank bearings as well as rings and honing the cylinders. Also, is there anything else I should consider doing with the motor apart? I've got mods in my sig, plus I'll be adding dual oil pumps next month.
Thanks.
02 CC 4x4. AFE stage 2, Magnaflow 4" exhaust, BTS tranny, live-tuned by Jody, AC singles, DI regulated return, Terminator HPOP, DR 4.5" lift & some other stuff...
sandnut is offline
post #2 of 10 (permalink) Old 02-13-2008, 05:29 PM
Banning Smut
PTSUPERD's Avatar
Re: Where can I go to get rods installed?
WOP in Utah
or maybe John Wood in Ca.?
PTSUPERD is offline
post #3 of 10 (permalink) Old 02-13-2008, 05:32 PM
fueled by Colecovision
golfer's Avatar
Garage
Thanks.
Does no one rebalance the crank with the lighter forged rods? or do y'all just swap them out and call it good?
golfer is offline
post #4 of 10 (permalink) Old 02-13-2008, 05:34 PM
Laces Out
bigrpowr's Avatar
typically any shop smart enough to do a rod swap is most likely smart enough to balance the crank.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #5 of 10 (permalink) Old 02-13-2008, 05:35 PM
Construction Babysitter
wooner's Avatar
For that price, why don't you order a new block from Lott with forged rods, new bearings, pistons, etc already in it?
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #6 of 10 (permalink) Old 02-13-2008, 05:52 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Thats what I was just going to say... $3500 from Lott, complete, no core charge, and all the gaskets, oil pump and such... Then figure another 2k for install and your there.
Mine was at 8k for everything installed, thats with the head work too.
Joe
CSIPSD is offline
post #7 of 10 (permalink) Old 02-13-2008, 06:12 PM Thread Starter
sandnut's Avatar
I hadn't thought of a short block, I'll have to look into that option, too.
sandnut is offline
post #8 of 10 (permalink) Old 02-13-2008, 06:13 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #9 of 10 (permalink) Old 02-13-2008, 06:15 PM
Banning Smut
PTSUPERD's Avatar
Good point wooner. Didnt even think about that.
If I was in those shoes, that is what I would do.
PTSUPERD is offline
post #10 of 10 (permalink) Old 02-13-2008, 07:27 PM
thetonka's Avatar
Once I hit 300K I am going to seriously look into the DI short block.
2001 F350 CC LB 4X4
TN, AIS, DP 80hp, ITP boost elim, Magnaflow 4".
Tows the big white hauler.
When life gives you Lemons, throw them at the stupid people.
thetonka is offline
