IDM mod preferences - PowerStrokeNation : Ford Powerstroke Diesel Forum
View Poll Results: Modification preferences
No IDM electronics modification 3 7.69%
Clumsy box between PCM and IDM- plain view 23 58.97%
Internal mod chip inside IDM - stealth mode 13 33.33%
Voters: 39. You may not vote on this poll
post #1 of 38 (permalink) Old 02-13-2008, 04:18 AM Thread Starter
IDM mod preferences
Andy
I would like to thank F.A.S.T. for helping with the 2008 pulling season.
For all your fire service repair and fabrication needs. Will travel.
IDM Info Updated 11/07/08
mustang_gt_350 is offline
post #2 of 38 (permalink) Old 02-13-2008, 04:31 AM
Re: IDM mod preferences
Where's the choice for non clumsy box that connects externally allowing you to revert to stock quickly?
Tenn01PSD350 is offline
post #3 of 38 (permalink) Old 02-13-2008, 04:33 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Are you going to build something or what?
Joe
CSIPSD is offline
post #4 of 38 (permalink) Old 02-13-2008, 04:41 AM
OverFuelingForYourPlesure
pontiacross's Avatar
If it allows me to turn 5,000 rpm. it could be a 2ft square box that mounts on top of the hood and I would still run it
but I would like something small external of the IDM that could be unpluged and run with out it
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #5 of 38 (permalink) Old 02-13-2008, 04:51 AM Thread Starter
Option #3 can be activated many ways. example 1. Driver interaction with the Throttle peddle. as in hold rpm for set time or tap from idle set # of times. Without it being activated it would be no different than a stock one would be.
Andy
post #6 of 38 (permalink) Old 02-13-2008, 04:52 AM
squeeks's Avatar
I like the clean, non-cluttered look, and besides the idm is easy enought to change on our obs's anyway, if something ever does happen that you dont want increased pulse width
1996 Ford F350 Regular Cab 5spd with the 7.3L PSD, 4x4, 35.5x12.5x16.5 All-Terrain T/A's, 3.73s', DIY Electric Reg Return Fuel Sys, 3" Downpipe, AFE Stg 2, 17* HPOP, IDM Mod, SB Con-O, Cat and Muffler Delete, AutoMeter NV Series Boost, Fuel Press. and Pyro, Autometer 3 Pod A-Pillar, TS Performance 6 Pos Chip. HPX Mod, 355,000 Miles
squeeks is offline
post #7 of 38 (permalink) Old 02-13-2008, 04:59 AM
2Cruel
moremph's Avatar
Yeah really, id just hide mine in the fender well, i dont care how big it is its a one ton!!
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
post #8 of 38 (permalink) Old 02-13-2008, 05:10 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Box between PCM and IDM is just fine. Easier to debug when problems arise. Leave my IDM alone except resistor mod!!
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #9 of 38 (permalink) Old 02-13-2008, 05:49 AM
What else?
smokyred's Avatar
Maybe you could mount it to the IDM on the outside, one less thing to mount underhood. And like Travis said, hide it in the fender so snoops can't see it.
Oh and make it so I don't have to hack my harness all up, if your little box screws up I don't want it totally downing my truck!
Dave
smokyred is offline
post #10 of 38 (permalink) Old 02-13-2008, 12:05 PM
HRT Performance
HotRodTractor's Avatar
Doesn't matter what it looks like as long as it works. I will find space and weight to make it fit.....
Jason
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
