Stuff for Hutch mods. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-06-2007, 09:37 PM Thread Starter
Where is the best place to get the tubing and compression fittings, fuel line, etc.
I'm also thinking of putting a pre pump filter and helper pump on eventually.
What would you do? 30mic pre pump spin on?
How long should this take?
gregrob is offline
post #2 of 3 (permalink) Old 08-06-2007, 09:50 PM
HP Junky
Re: Stuff for Hutch mods.
Gregory- I went with ITP's 5/8" pickup and then bought a filter head and 30 mic water seperator filter for it to plug into.
The bonus is that the filter head I'm using has two inlets and two outlets. So you could cap the one outlet and if you decide to run a second fuel pump you'd just have to take the plug out and run a hose to the new pump.
RockinJW is offline
post #3 of 3 (permalink) Old 08-07-2007, 01:31 AM
<- Sums it up
strokin_early_99's Avatar
5/16" compression union (steel fitting, brass can break)
3/8" compression union (steel fitting, brass will break)
3 1/2" - 3/8" SS tubing
20" - 5/16" SS tubing
I went to my local Parker store. Try here: http://www.discounthydraulichose.com...305-parent.htm
They will have everything you need or you can buy it from ITP diesel. Dennis puts together a very nice kit for a very reasonable price.
Keep Strokin'
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
