red tube on wastegate - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 02-12-2008, 06:19 PM Thread Starter
I have read about this before but don't remember. If I put a non-wastegated housing on my 01 what do I need to do with the red tube going into the wastegate?
Thanks,
Ted
Tedb is offline
post #2 of 20 (permalink) Old 02-12-2008, 06:19 PM
fbilly420's Avatar
Re: red tube on wastegate
plug it.
Billy
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #3 of 20 (permalink) Old 02-12-2008, 06:20 PM
or leave it alone.
gregrob is offline
post #4 of 20 (permalink) Old 02-12-2008, 06:21 PM Thread Starter
does the green one need to be pluged into the intake?
Tedb is offline
post #5 of 20 (permalink) Old 02-12-2008, 06:22 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Originally Posted by gregrob View Post
or leave it alone.
It starts to vent boost at 5-7 psi... All be it a small amount but...
You dont need the whole works, remove the green line that goes to the intake, plug that whole. Remove the red line that goes to the Y pipe, plug it. Unplug the controler, and remove the whole thing.
Joe
CSIPSD is offline
post #6 of 20 (permalink) Old 02-12-2008, 06:24 PM
Whats your point
gregrob is offline
post #7 of 20 (permalink) Old 02-12-2008, 06:59 PM
CSIPSD's Avatar
Whats your point
You want a boost leak?
Joe
CSIPSD is offline
post #8 of 20 (permalink) Old 02-12-2008, 07:06 PM
If you leave it plugged in like it is from the factory there is no boost leak.
gregrob is offline
post #9 of 20 (permalink) Old 02-12-2008, 08:20 PM
CSIPSD's Avatar
If you go to a non wastegated housing what are you going to plug it into?
Joe
CSIPSD is offline
post #10 of 20 (permalink) Old 02-12-2008, 08:23 PM
sttstroke's Avatar
I have my whole plug unpluged is that ok??
Sold
sttstroke is offline
