b codes with small oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 06-30-2010, 04:50 PM Thread Starter
master fabricator
does anyone have any first hand experience running b code injectors with small oil i.e. an adrenaline pump? i have a customer that just picked up a set of 350/200 b-codes that he is convinced will run with an adrenaline pump. i dont have any experience with b codes, just hybrids. as far as i am aware, an adrenaline starts struggeling after about a 250/100 hybrid.
thanks,
barry
B and S Performance
FBR Motorsports
Custom Fabrication and Machine
1997 f350 4x4 standard cab
12v cummins
hx40w over s480
zf 6 speed
4.10 gears
38" toyo mt's
19?9 ford f??0 standard cab
300/200 hybrids maybe bigger
big turbos
4r100
fastbarryracing is offline
post #2 of 27 (permalink) Old 06-30-2010, 05:12 PM
Hater Club
Dirk's Avatar
Re: b codes with small oil
Adrenaline wont keep up with those at all. Even Bob states NO B CODES on his site.
That being said.. will it run? Sure. It will be smokey as hell and you won't be able to keep ICP up. He can try it, but all he will be doing is basically short stroking the injectors due to low volume (and low ICP as a result) of oil.
EDIT: I think there are a few different adrenaline pumps feed different 250cc hybrid configurations (80\100\200 nozzles).
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #3 of 27 (permalink) Old 06-30-2010, 09:44 PM
Junior Mint
I had around an 80% nozzle on some B-codes a while back w/ a single stock 15 degree pump and it would drop the HPO pretty good.
If he is asking for any kind of pw it's simply not going to be enough.
I wouldn't worry about it because some people you just can't tell a thing. He'll figure it out eventually.
I'm officially...Stroke-less.
Suns_PSD is offline
post #4 of 27 (permalink) Old 06-30-2010, 11:52 PM
Hater Club
Dirk's Avatar
Expensive lesson, but I agree.
Dirk is offline
post #5 of 27 (permalink) Old 07-01-2010, 07:22 AM Thread Starter
master fabricator
thanks guys. that was pretty much what i have been trying to tell him.
barry
FBR Motorsports
12v cummins
hx40w over s480
zf 6 speed
4.10 gears
38" toyo mt's
big turbos
4r100
post #6 of 27 (permalink) Old 07-01-2010, 12:24 PM
dinnerbooter treasurer
genuineford's Avatar
I am running some 300/200 hybrids with an adrenaline pump and it will hold 2600 psi on a wot run.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #7 of 27 (permalink) Old 07-01-2010, 08:35 PM
What else?
smokyred's Avatar
Give Bob a call, IIRC, he is running a set of B-codes and an ADR in one of his personal trucks right now, and he would most likely be the one with any info anyways.
Dave
smokyred is offline
post #8 of 27 (permalink) Old 07-01-2010, 08:55 PM
Hater Club
Dirk's Avatar
completely different animals.
Dave
I believe that they are smaller B codes..
The 350/200's will need big oil.
Dirk is offline
post #9 of 27 (permalink) Old 07-01-2010, 10:48 PM
I know they are not anywere close to the same I was just putting the info that I had about my pump into this thread.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
post #10 of 27 (permalink) Old 07-01-2010, 11:13 PM
Junior Mint
It's really about the injection ratio and the size of the nozzles. Hybrids and/ or smaller nozzles will require a lot less HPO.
B codes w/ 200%ers are going to require lots of oil.
Suns_PSD is offline
