Truck Stalls - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-30-2010, 03:51 PM Thread Starter
Truck Stalls
I have a 2001 F250 w/ the 7.3 and sometimes the truck will stall randomly. It will happen when the truck is shifted into a gear. Often from reverse to drive but other times it will stall in intersections as well . It does have a 4 position TS chip. I recently took it into a shop so they can run some codes and they came out with a "PCM Failure" code. Is it possible for the truck to run and still have PCM failure or does the PCM either work or completely fail. Regardless, I feel that this is an issue with the chip or its installation and will be removing it in the meantime. Just was wondering what your guys' opinions/comments were.
Thanks
2001 F350 SRW, Extended Cab Longbed
DP Tuned, 6" Superlift, 35 BFG MT's on Mickey Thompson 16x10's, 6" Turnout Stacks, DiPricol Optix x3, Warn Hubs, 6637 intake
edub32 is offline
post #2 of 2 (permalink) Old 06-30-2010, 08:12 PM
Re: Truck Stalls
Pull the chip and see if it does it, if not then it may be caused by the chip or someone who installed the chip cleaned off the contacts too much on the pcm.
02 f250
countryboyrob is offline
