Best mod for the money - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-12-2008, 04:18 PM Thread Starter
sttstroke's Avatar
I know this has probly been asked a hundred times sorry. But whats the best mod for around $1000? Someone said I can send my injectors to Sheid and I guess get different nozzles for $1200 (not sure what they do)
Sold
sttstroke is offline
post #2 of 13 (permalink) Old 02-12-2008, 04:34 PM
Haul_n_horses2's Avatar
Re: Best mod for the money
After gauges, air and exhaust, tuning, I would say fuel system upgrades and regulated return. If you already have those, I would consider medium oil Stealth, Pulse or Cardiac Arrest if it is available.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #3 of 13 (permalink) Old 02-12-2008, 04:40 PM
Absolute best bang for the buck as far as HP goes would be to get a set of bigger injectors, but you'll be about double your figure. Nozzles on stock AD's are only good for around 50hp at the tires +/-. I'd get DDP nozzles if you are going that route.
Besides a fuel system you already have as much of the inexpensive bolt on stuff. Next step for HP is bigger ticket items like injectors and oil and turbos.
69W900A is offline
post #4 of 13 (permalink) Old 02-12-2008, 05:15 PM
There isn't one. Because everything you buy requires 3 supporting mods for it run worth a crap.
Don't kid yourself into thinking you can spend 1K and be done
Honestly, if I had a K and it to do all over again I would save it and put it toward injectors, turbo or fuel system.
Fuel system is kind of a caveat to what I said, you can do it and see benefits on a bone stock truck.
That's probably what I'd do, full fuel system from the tank forward. ITP regulated return, get rid of the bowl, do the intank mods etc etc etc etc etc
gregrob is offline
post #5 of 13 (permalink) Old 02-12-2008, 06:08 PM Thread Starter
sttstroke's Avatar
So what is Sheid doing to the stock injectors for $1200 dollars. There used to be a truck around here that had it done and it smoked like a train but I don't know about the power.
Sold
post #6 of 13 (permalink) Old 02-12-2008, 06:09 PM
Adding nozzles
gregrob is offline
post #7 of 13 (permalink) Old 02-12-2008, 07:04 PM
just send off your nozzles to get eh'd. same exact thing they are doing, just cheaper for you
PMRCM#1
slowleak is offline
post #8 of 13 (permalink) Old 02-12-2008, 07:05 PM
I wouldn't get used nozzles enlargened. I would use new.
gregrob is offline
post #9 of 13 (permalink) Old 02-12-2008, 07:08 PM
why is that?
PMRCM#1
slowleak is offline
post #10 of 13 (permalink) Old 02-12-2008, 07:09 PM
Because they will be more prone to break and take out a piston.
gregrob is offline
