Weak turbo?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-30-2010, 12:40 AM Thread Starter
Firefighter/EMT
NH OIL BURNER's Avatar
Weak turbo??
Hey guys im trying to figure out if my turbo is going bad or is bad...my truck has 218k on the stock turbo. When i put my DP tuner in about 2 months ago i could hit around 20psi max on the highest setting, today i tried a WOT run in my DD tune which is 80hp and could only hit just under 15psi. I dont know if this is normal or if its weak, another thing i should mention is that when it gets nice and warm it will puff some bluish white smoke for a couple seconds when i let off i do have the ccv done so im guessing this is oil from the turbo being burnt off? any help would be great!
Jeff
02 F250 6 speed with 270k- SOLD
05 F350 auto with 94k, 4in MBRP with 6in tip, updated fuel pressure spring, and auto meter fuel press, boost, trans, and pyro guages, and tuning by vivian and PHP's FICM tuner currently running hercules! NO STUDS!
14.1 @ 95 is the best so far!
NH OIL BURNER is offline
post #2 of 10 (permalink) Old 06-30-2010, 12:47 AM
Myles_S's Avatar
Re: Weak turbo??
check for boost leaks first.
Pull the intake boot off and check turbo for shaft play
Then come ask questions
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #3 of 10 (permalink) Old 06-30-2010, 12:51 AM Thread Starter
Firefighter/EMT
Re: Weak turbo??
I already did a leak test with an air hose but i have not checked shaft play...should there be any at all?
post #4 of 10 (permalink) Old 06-30-2010, 01:21 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: Weak turbo??
Yes,but very little at all.There should be more in and out than up and down.The oil will center the journal bearings while the motor is runnin.
Check for leaks in all of your boots and Y-pipe.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #5 of 10 (permalink) Old 06-30-2010, 01:23 AM
TARM's Avatar
Re: Weak turbo??
What are your EGTS running. Do you have a boost fooler. Have you pulled your codes yet? Look for a low boost / no boost code. Could be you MAP is bad. Have you wired your waste gate shut to ensure it is not the cause. Of course as has been said check for play any more then the slightest bit is a sign things are going south.
The blueish white smoke could more likely be worn injectors/o-rings as you do have over 200K on it.
TARM is offline
post #6 of 10 (permalink) Old 06-30-2010, 02:16 AM Thread Starter
Firefighter/EMT
Re: Weak turbo??
My EGTs are about 500 to 700 with normal driving and i can get them to 950 if i really push it. (my probe is in my down pipe ) I will check for shaft play and i have been thinking of doing at least injector O-rings. I have a bad oil leak which looks like its coming from the rear main or oil pan or maybe even the turbo. i will be pulling the motor one of these weekends to take a look. Im going to see if a fuel injector place around here will rebuild the ones i got for not alot of money but we will see....
post #7 of 10 (permalink) Old 06-30-2010, 02:20 AM
owner/president
Re: Weak turbo??
I doubt your rear main is leaking..Check you turbo pedistal o-rings,oil rails and your hpop fittings and/or seal.
post #8 of 10 (permalink) Old 06-30-2010, 02:22 AM Thread Starter
Firefighter/EMT
Re: Weak turbo??
I am glad you said that because i have heard from a few people now that the rear main seals rarely leak on these. If its the turbo, which i can check without pulling the motor it would save me alot of time and money...
post #9 of 10 (permalink) Old 06-30-2010, 05:05 AM
TARM's Avatar
Re: Weak turbo??
That would be my bet. Clean up the entire valley etc and get it running and see where its coming from. I ahve the same issue but its not bad a few drops when its parked.
TARM is offline
post #10 of 10 (permalink) Old 06-30-2010, 01:10 PM
dinnerbooter treasurer
genuineford's Avatar
Re: Weak turbo??
If it is a leaking hpop line that may explain some of your low boost numbers.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
