Need help Fluid from tailpipe and rough idle after injectors were installed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 06-29-2010, 11:03 PM Thread Starter
Well I worked all day and finally got my truck put back together. I did everything by the book. Removed injectors sent them to Rosewood. Got my Stage 2's back installed them, no glow plugs in, then purged cylinders until just a fine mist blew out. I then buttoned everything back up. Installed used 47k mile van turbo. Got it all back together and it took about 5 minutes before she rolled over. It blew blackish white smoke for a minute then cleared up. I let it idle for 2 minutes then shut it off. Waited a minute then started it back up. It took a few tries but it turned over. Blew more white then black this time then cleared up. I then let it run for about 5 minutes then shut it down. The whole time it shakes a little... nothing crazy but it is a noticable shake. I then started it again and drove it around and around my block for about 10 miles. Still blew some white smoke but would clear up from time to time. Not a whole lot of smoke but it was still there. I pulled back into my driveway and shut it down. Got back out and did a walk around. I noticed black liquid dripping out of my tailpipe. It did not really have a smell that I could put my finger on... maybe diesel fuel? Anyway it still shakes and there is fluid in the tailpipe. Anyone know what is going on?
Stuff I did was:
-Rosewood Stage 2 Single Shots 160cc/80%
-47k mile Van turbo with adapter
-BTS Valve Body
-BDP custom tunes on TS style chip
BTW I don't know whats going on with BDP but I have placed like 15-20 calls to them today and not one time did anyone answer the phone.
2000 F-350 Crew Cab - 7.3L Turbo Diesel, .10 Over Block w/ Machined Mahle Pistons, Cryo'd Forged Rods, Melling LPOP, Fully Balanced Engine, Rosewood 250cc/100%, BatMoWheel'd 1.15 38r, SRP1, ITP RR, 910's, DI Pushrods, ARP Studs, Walbro Pump, BDP Live Tuned, and BTS Converter+VB+Pump Mods.
545rwhp/1,243rwtq - w/o Built Engine and BatMoWheel
Wickky is offline
post #2 of 30 (permalink) Old 06-29-2010, 11:06 PM
Proud Sponsor
Abrannan19's Avatar
Re: Need help... BDP wont answer there phone.
why would the title of this thread be named "BDP wont answer the phone" that's not even relevant to your problem, you have a misc fluid dripping from your tailpipe and the first person you call is your tuner..not hard parts such as injectors..but tuning..
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 30 (permalink) Old 06-29-2010, 11:07 PM
Stroken it 7.3,6.0,6.4
weekendwarriorfsw32's Avatar
Might be a injector cup.
08 F 450 King Ranch 6.4
Elite Race trans, Spartanized, ARP, Icon 4.5 on 35's, RDP boots, HID'S, OUO ladder bars, 3" I/C pipe
04 X 6.0
08 tow mirrors, ARP studs, RDP boots.
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB holding on for dear life @40+psi, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots
weekendwarriorfsw32 is offline
post #4 of 30 (permalink) Old 06-29-2010, 11:08 PM
I personally wouldnt have started it up then shut it down, then restart it again then shut it down. start it up let it idle for a few, rev it some then take her for a spin to get the air out.
02 f250
countryboyrob is offline
post #5 of 30 (permalink) Old 06-29-2010, 11:10 PM Thread Starter
This is my first time working on diesels. I contacted Strictlydiesel and I explained the problem and they said it was in the tuning. Thats why I am pissed because they told me it is most likely split shot tunes for single shot injectors.
Wickky is offline
post #6 of 30 (permalink) Old 06-29-2010, 11:11 PM
Busted Knuckles
PSDEng's Avatar
First of all drive it like you stole it before you try assessing any problems which of none you have probably. Secondly BDP is extremely busy this time of year plus if you called in the middle of the day they, like the rest of us, like to eat lunch. If you leave them a voicemail they will get back to you. Highly doubt it has anything to do with your chip anyway.
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #7 of 30 (permalink) Old 06-29-2010, 11:12 PM Thread Starter
When I first purged the cylinders I had about 6-8 oz of coolant blow out of one of the holes. I then waited 10 minutes and tried it again and no more coolant.
Wickky is offline
post #8 of 30 (permalink) Old 06-29-2010, 11:13 PM Thread Starter
Yea I have been calling them all day from about 11:30 till they closed. Roughly every half hour till it was passed there closing time.
Wickky is offline
post #9 of 30 (permalink) Old 06-29-2010, 11:16 PM
Busted Knuckles
PSDEng's Avatar
Re: Need help Fluid from tailpipe and rough idle after injectors were installed
Yeah man like I said they get really swamped heck they even posted on here awhile back that they needed extra help. I'm sure if it's their tunes they'll make it right but make sure you drive that truck like ya stole it before you do anything. Most likely it will smooth out.
PSDEng is offline
post #10 of 30 (permalink) Old 06-29-2010, 11:17 PM
OEM Moderator
Tom S's Avatar
I retitled this thread to better reflect the issues at hand. I am also curious if you left a message or just kept on calling.
Tom S is offline
