Walbro Went In Yesterday - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 72 (permalink) Old 02-12-2008, 01:12 PM Thread Starter
The Walbro pump went in and has fixed the fuel starvation issue I wass having. These injectors do need more fuel and the stock pump could not do it. So now my shifts are nice and clean. At WOT I only drop 3 lbs of fuel pressure.
All I have to say is WOW this truck is pretty quick now. Already in the mid 9's at about 1/2 throttle in the 1/8th. I am looking forward to some better times now.
If anyone is having fuel pressure problems Walbro or Bosch. I got 2 Walbro pumps for the price of the Bosch and one is in my toolbox.
NWSUPRD is offline
post #2 of 72 (permalink) Old 02-28-2008, 12:28 PM
Lurker...
Fever's Avatar
Re: Walbro Went In Yesterday
what part number Walbro did you use?
2003 F-350 Super Duty
Fever is offline
post #3 of 72 (permalink) Old 02-28-2008, 12:41 PM Thread Starter
It is the GSL-392 and pumps 255 lph. Hope this helps. It holds pressure very nicely. I purchased it at aztpi.com
Last edited by imelmo; 02-28-2008 at 06:29 PM. Reason: No direct links for non-sponsors
NWSUPRD is offline
post #4 of 72 (permalink) Old 02-28-2008, 01:29 PM
Sleep well my brothers
yamt03's Avatar
So did you replace your stock pump with this or are they working in parallel?
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #5 of 72 (permalink) Old 02-28-2008, 01:40 PM
<- Sums it up
strokin_early_99's Avatar
When I had my walbro set at 60psi I was getting a pressure drop. I bumped it to 62psi(after warmed up) the pressure does not drop at all any more. The first trip down the strip this last weekend I was watching the fuel pressure gauge very closely and it did not budge off 62psi.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #6 of 72 (permalink) Old 02-28-2008, 05:14 PM
Lurker...
Fever's Avatar
just checking, had a buddy lose a pump last night and was thinking of going with a Bosch one, i had suggested the Walbro as an option also...
Fever is offline
post #7 of 72 (permalink) Old 02-29-2008, 01:41 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Thanks to Strokin early 99's previous testimonies on the walbro thats what I will be getting eventually.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #8 of 72 (permalink) Old 03-01-2008, 01:07 AM
Banned
Send a message via Yahoo to blk99
what is the difference between the Walbro GSL-392 and the GSL-395???? they are both the same price....
blk99 is offline
post #9 of 72 (permalink) Old 03-01-2008, 02:01 AM
<- Sums it up
The Walbro GSL395 pump is for low pressure applications such as TBI installations. The pump can generate over 30 PSI but is designed to run at 10-15 PSI.
The Walbro GSL392 pump is for high pressure applications such as TPI, LT1, LS1 and Vortec installations. The pump can generate over 100 PSI but is designed to run at 35-65 PSI.
This info taken from AZTPI.com
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #10 of 72 (permalink) Old 03-02-2008, 01:28 PM Thread Starter
Yes thanks to Strokin early also. It was his posts I read that lead me to this fuel pump. I am running around 71 psi seems my injectors like it a bit better.
NWSUPRD is offline
