DD Tune? What's yours and why? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 50 (permalink) Old 06-29-2010, 03:47 AM Thread Starter
Myles_S's Avatar
*Looking to keep this thread halfway organized for obvious reasons so please no derailing guys*
Let's see how great some of y'all are at following directions.
Tell me:
-Who tuned it
-Your DD tune
-MPG increase you saw with this file
-EGT'S, and Boost at normal cruising speed
-Why you like it so much as to make it your DD over the other tunes.
-Anything you would change to it.
Feel free to chime in with small chit chat over the tune.
Not about what injectors you want or turbo etc...strictly DD stuff please
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #2 of 50 (permalink) Old 06-29-2010, 05:16 AM
"Smoke A Lil Smoke"
chappy's Avatar
Re: DD Tune? What's yours and why?
Bill at php
140 tune but once in awhile 80 performance
not sure
I wanna say 6-700 at 55mph and maybe 2-3 boost
I just like having the most power on tap and I like the slight haze coming out my stack.The pedal is completely linear so its very easy to drive in dd.I got 21.7 mpg on my last trip going average 70mph in it.
I would change it so it shifts sooner at part throttle into overdrive before 55mph.But its probably better on my trans with stock 3.73's and 35's so I stick with it.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
post #3 of 50 (permalink) Old 06-29-2010, 05:51 AM Thread Starter
Myles_S's Avatar
Thanks chappy, exactly what I was looking for.
Black Ops 360
Myles_S is offline
post #4 of 50 (permalink) Old 06-29-2010, 05:59 AM
Firehunter's Avatar
Originally Posted by Myles_S View Post
Tell me:
-Who tuned it
-Your DD tune
*Jody @ DP Tuner
*60tow (circa 2005)
*+1 mpg overall
*EGT's are almost always 10X the speedo - 60mph = 600* EGT, 70mph = 700*, etc...
*I like it because it was my only tune for a couple of years - it's on my PCM.
I put "circa 2005" next to the tune because it seems to have changed over the years. I recently had his 60tow program on a chip (2/09) and the throttle is more responsive, engine is noisier, and mileage went back down to what it was stock. I am now back to the original 60tow on the PCM and my mileage is back too.
I have some PHP tunes on the way to try, should be here next week. Reviews to follow.
2000 F350 PSD, 4X4, CC, LB, 6-speed/ PHP Tuning /1.0 Turbo (no wastegate) with WW/ 4" turbo back exhaust/ AIS Intake with fender sleeve/ Isspro EV gauges/
Just because you can, doesn't mean you should!
Firehunter is offline
post #5 of 50 (permalink) Old 06-29-2010, 06:03 AM Thread Starter
Myles_S's Avatar
Curious too see some stuff from gearhead and swamps..
Black Ops 360
Myles_S is offline
post #6 of 50 (permalink) Old 06-29-2010, 07:13 AM
Homesteader's Avatar
[email protected] Dp
80E When wife drives 120 when I drive
Haven't check fuel MPG yet.
EGTs about 600 @ 55-60mph ,boost @ about 3-4 psi
I like my DD because I know I got the HP if I need it.
Maybe a different tuner.
Homesteader is offline
post #7 of 50 (permalink) Old 06-29-2010, 07:16 AM
Thomas7.3psd's Avatar
Matt @ Gearhead
#4 (street muscle)
+2 mpg gain.
egt about 6-7 @80mph
I like the shift points.
no changes reccomended.
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #8 of 50 (permalink) Old 06-29-2010, 07:43 AM
TARM's Avatar
Same as above
But woudl add pedal is 1:1 on throttle. No touchy pedal. 1/4 pedal gets you 1/4 throttle.
Boost fooler not needed as he can program the map.
Very good off boost throttle response.
Gained 2-3 mpg depending where i am driving
Overhead mpg calculator works accurately which most tunes screw up. In fact stock it was off by about .5-1 mpg and the chip made it almost dead on accurate.
Little if any smoke.
I usually run in the 5th position.
Can't think of anything I would change. I am sure some small tweaks could be made with live tuning as all tunes can but doubt it would be anything that noticeable.
TARM is offline
post #9 of 50 (permalink) Old 06-29-2010, 10:57 AM
riverjet
Dp tuner
80e
maybe 1mpg
egt 550-600 at cruise-70mph no load/boost3-4 lbs
shifts alittle softer than 120r
changes-make 3-4 upshift occur at 41mph instead of 45 get rid of stupid 4-3 downshift at 45 mph.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #10 of 50 (permalink) Old 06-29-2010, 12:24 PM
A Ghost these days...
farm boy's Avatar
I run around/light tow in my 2nd power setting, which is the 4th position. Boost: couple lbs, hard to tell. Tuned by Matt Robinson. I couldn't ask for much more. Im running low 14's in a fat ass farm truck with PMR's......
1) heavy tow
2) high idle
3) quiet (drive through tune)
4) street muscle
5) faster (my race tune)
6) fastest (gets too hot for me)
EGT's are about 700* @ 65mph. I cant keep my foot out of it enough to get a good city driving mpg reading. I did get about 18 mpg last highway trip I took though.
Oh yea, 238cc/80% over nozzles.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
