Pulse vs. Stealth - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 124 (permalink) Old 02-11-2008, 10:35 PM Thread Starter
Canadian Powerstroker!
Oilfield_Digger's Avatar
Pulse vs. Stealth
Lets have it out what is the pulse compared to the stage II stealth? Lets hear the pro's and cons of both.. has anyone actually run either of these yet? I am looking at doing a 38R, and mini me's which one should i get?
03 7.3L F-350 Lariat FX4 CC LB
Mods: TN BB Turbo, NADP Heavy Hauler Tranny, DP F-5, Quad Pod w/ Autometer Phantom II's, AFE II PG7, AFE 409 SS 4" Exhaust, CCV, HPX, Non-EBPV & HFO, 95 Gal Aux tank/tool box, ITP OBA.
Oilfield_Digger is offline
post #2 of 124 (permalink) Old 02-11-2008, 10:40 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: Pulse vs. Stealth
Pulse is ALOT cheaper.
Stock
PowerstrokeJunkie is offline
post #3 of 124 (permalink) Old 02-11-2008, 10:48 PM
Phatbulldog's Avatar
Send a message via Yahoo to Phatbulldog
I run hybrids (basically mini me's) and I don't need big oil. I want it but I don't need it. I haven't thrown a CEL yet.
1997 F-250 CC 4x4.
2008 F-250cc 4x4 6.4 Powerstroke.
Phatbulldog is offline
post #4 of 124 (permalink) Old 02-11-2008, 10:52 PM
Banned
OH NO
not another B.O. Thread
whiteduallyil is offline
post #5 of 124 (permalink) Old 02-11-2008, 10:57 PM Thread Starter
why is the pulse so much cheaper? and i can run non hybrids stage 3 or 4's if you run BO
post #6 of 124 (permalink) Old 02-11-2008, 11:28 PM
Harry Callahan
First ask "what am I wanting to do with this truck"!! Hybrids and stock HPOP will get you over 500hp, and that is a big-time powerful truck. If you want to race and don't mind blowing stuff up like transmissions, differentials, and engine blocks then go for it.
RDRCM#10
A select band of brothers- We stand together as one.
Giant VT-3, not stock
sniperonhigh is offline
post #7 of 124 (permalink) Old 02-11-2008, 11:43 PM
Im thinking you should probably compare the stealth stage 1 pump with a pulse and even then im fairly certain that the stealth will out flow the pulse. Stage 2 stealth out flows 2 stock pumps there is NO way a pulse pump can hang with that.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #8 of 124 (permalink) Old 02-11-2008, 11:50 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
The Pulse uses the stock hpop housing with upgraded internals to flow more than stock and the Stealth uses a newly designed hpop housing with all new internals inside for better than stock flow. So the stealth is going to cost more because for the design and manufacture of the housing and internals.
That is how I see the cost difference of the two units. End result is better than stock oil pressure from both units.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #9 of 124 (permalink) Old 02-12-2008, 12:11 AM Thread Starter
i am worried about my hybrids falling on their face with stock oil.. I put a computer on my truck with no chip on it once i got my new motor in and it kept solid around 2900 psi when floored.. I am not sure if that will hold upto hybrids.. or will it?
post #10 of 124 (permalink) Old 02-12-2008, 12:27 AM
squeeks's Avatar
Theres only one way to find out
1996 Ford F350 Regular Cab 5spd with the 7.3L PSD, 4x4, 35.5x12.5x16.5 All-Terrain T/A's, 3.73s', DIY Electric Reg Return Fuel Sys, 3" Downpipe, AFE Stg 2, 17* HPOP, IDM Mod, SB Con-O, Cat and Muffler Delete, AutoMeter NV Series Boost, Fuel Press. and Pyro, Autometer 3 Pod A-Pillar, TS Performance 6 Pos Chip. HPX Mod, 355,000 Miles
squeeks is offline
